Thread: Clutch, tranny and diff change
06-25-2012, 07:46 AM #1
So I gotta change all those fluids and I did a search and came up with these results...
For the clutch, it kinda works like bleeding a one-wheeled brake system right? And I gotta use a Dot-3 fluid? Anybody have a specific brand and how much is required?
For the tranny (M6) its about 4 qts of Dexron III right? It doesn't have a filter and its basically just flush and fill right?
Differential I'm going with 2 quarts of RP 75-90 and no additive is needed right? I'm familiar with this process just got question on the additive.
06-29-2012, 06:17 AM #2
To bleed the clutch is just like doing brakes. Pump the clutch, hold it down. Open the bleeder. Close the bleeder. Pump the clutch. Repeat.
You can use DOT3 or DOT4. Use whichever brand has the highest boiling point.
The tranny holds just under 4qts. There is no transmission filter on a T56. Just drain and fill.
For the diff you may need additive. If you have an Auburn differential you'll need to add posi additive. If you have a zexel torsen then you don't have to add anything extra. There is a service bulletin for the zexel torsen if it makes slight noise you can put in the additive to quiet it down. I had a zexel torsen and never used anything other than synthetic Mobil1 fluid.
07-30-2012, 02:54 PM #3
07-30-2012, 03:48 PM #4
I ran Royal Purple 75-90 and added the GM additive for the posi
07-31-2012, 04:03 PM #5
07-31-2012, 05:45 PM #6
07-31-2012, 06:26 PM #7
You can purchase posi-additive at just about any parts store. Our year cars have a Torsen style differential, so there are no clutches and the additive is not required. There is, however, a bulletin out about using it in our rears to eliminate a "rusty screw" noise that some owners have complained of.
08-03-2012, 03:55 PM #8Senior Member
- Apr 2011
- Johnstown,PA
Silver- 1999 Trans-Am, 2012 Sonic
Sounds like it wouldn't hurt to just add it for piece of mind..
Rear diff and tranny help
By 200z28ss in forum Forced InductionReplies: 31Last Post: 01-09-2012, 11:29 PM -
rear diff. fluid change
By z28_81 in forum DrivetrainReplies: 3Last Post: 06-06-2009, 10:37 AM -
M6 tranny and diff oil change.
By seasponge in forum DrivetrainReplies: 2Last Post: 07-30-2007, 04:53 PM -
Real quick! How many quarts for diff change?
By ErikElvis in forum DrivetrainReplies: 2Last Post: 08-17-2006, 04:54 PM -
tranny and diff for vette
By Duke of Cruel in forum Manual TransmissionReplies: 1Last Post: 07-05-2006, 05:04 AM
