    Dec 2010
    st louis mo
    medium blue metallic
    what angle of driveshaft do i need
    im putting a UMI torque arm on my TA and was wondering what angle my driveshaft should be at and all that jazz..any help would be awesome!
    Member Supershafts's Avatar
    Apr 2010
    Long Island, N.Y.
    1971, 73,78, 85,92,95,
    1 to 1.5 degree difference than the shafts angle at the pinion in the negative side.
    So if the shaft is at 0.0 you want the pin pointing down 1.5 degrees.
    Auto or manual? With an automatic transmission you run just a little less down angle than a manual. Negative 1.5 is generally the setup for an auto equipped car.
    Dec 2010
    st louis mo
    thanks. i drove it last night and there was a pop/banging noise coming from the back. im guessing thats the issue.
    Apr 2010
    Long Island, N.Y.
    No a popping banging noise is not a angle issue
    Member RichWS6's Avatar
    Tucson AZ
    2001 Pontiac Trans am WS6
    Quote Originally Posted by Supershafts View Post
    I had the same problem when I installed mine, I had a tunnel mounted arm on my 9" axle, turned out I had clearance issues in the tunnel. I went back to a transmission crossmember mounted arm and a new trans bushing and it went away for me.
    Apr 2010
    Long Island, N.Y.
    See if you have the same problem as Richws6 mbmta99.
    A wrong pin angle will make a strong vibration or a strong shudder under load
  1. vibration at the seats, bad driveshaft angle?
    By JayTA98 in forum Drivetrain
    Last Post: 12-27-2010, 08:40 AM
  2. Pinion Angle
    By pajeff02 in forum Drivetrain
    Last Post: 04-05-2010, 08:45 AM
  3. radiator angle
    By Ramairgod84 in forum External Engine
    Last Post: 12-23-2009, 09:39 AM
  4. lca angle
    By RealLiveMD in forum Suspension and Handling
    Last Post: 10-21-2009, 04:33 AM
  5. pinion angle help please
    By shawn2002z28 in forum Drivetrain
    Last Post: 04-10-2006, 01:58 PM
