Results 1 to 20 of 58
06-07-2012, 01:24 PM #1
SES Flashing, Lean bank 1, Misfire #6 running poorly
As state above the SES Flashing, Lean bank 1, Misfire #6 running poorly... Anyone with suggestions?
All new o2's about 10k ago, WB o2 reading 17.9 and --- and sounds like it's starving and shaking badly. New plugs and wires EGR and AIR was deleted when the LTH's, ORY and SLP Exhaust installed about 10k ago as well.2000 Trans Am - Sold
BBK LT's, ORY, SLP LM2, SLP Cold Air Intake, Wide Band O2, American Racing Torq Thrust 2's, Founders STB, LCA's, LCA Relocation Brackets, Adjustable PHB, BMR Lowering Springs. Deleted AIR & EGR & Tuned By Frost. 1 of 23 MRM with options.
2009 Pontiac G8 GT Stock
06-07-2012, 01:30 PM #2Spaz is My Mentor
check fuel pressure at the rails. At idle should be around 50 psi.
06-07-2012, 01:42 PM #3
Don't have a fuel pressure gauge...
06-07-2012, 02:15 PM #411 years of bangin gears
- Jan 2009
- North Jersey
Did you check the wire on coil number 6? Could be loose. Check your coil pack for that cylinder as well. For a start anyway.
06-07-2012, 02:55 PM #5Senior Member
- Nov 2006
- Indianapolis
When did you last clean your MAF? Usually that shows up as lean on both banks, tho, like a fuel pressure problem would. Any vacuum leaks? Is your injector firing? You could swap it out to another cylinder to see if the missfire follows, if you've already ruled out an ignition problem.
06-07-2012, 05:44 PM #6Spaz is My Mentor
gauge you can pick up at parts stores for around $20
06-08-2012, 02:43 PM #7
Come to find out it seems to be a back coil pack on #6. The tech also stated that they are firing way to high. Should be between 10-12k and are firing around 15-18k. Is this something that could have happened during the tune? I'll pull the plugs on it tomorrow and take a look and see if they are white. If that is the case, should I not run the car until it is retuned to make that adjustment? If so, I am going to take my lashing for not using Frost.
06-08-2012, 02:46 PM #8
06-08-2012, 02:52 PM #911 years of bangin gears
- Jan 2009
- North Jersey
Your tuner could have made the computer run too lean.
06-08-2012, 04:12 PM #10
06-08-2012, 06:19 PM #11
I would NOT drive the car with it running that lean. You are asking for detonation to occur.
06-08-2012, 07:47 PM #1211 years of bangin gears
- Jan 2009
- North Jersey
Ditto on what Jon said. Put the car away and send your PCM to Frost for a tune. Let him work his magic.
06-09-2012, 04:55 AM #13None Shall Pass
- Jan 2010
- East of Cleveland, Ohio
Black- 99 WS.6 - Modified
I'm also with Rich and Jon. Don't run the car until the issue is fixed.
06-09-2012, 10:32 AM #14
Replaced the coil pack on #6. AFR is back to reading between 14.5-15 at idle and driving. It is also correcting itself where it couldn't before. The #6 plug was also replaced and doesn't look bad. Still a small misfire but noting too noticeable. Will replace rest of plugs when engine is cooled down. Any additional thoughts? It was tuned almost 3 months ago and have put 7000 miles on it with out a problem until then. I know I need a tune by Frost, but is it safe to drive now?
06-09-2012, 01:03 PM #15
06-10-2012, 03:05 PM #16
Please let me note that it is lean on Bank 2 not Bank 1 as stated in the subject, that was my error.
06-10-2012, 03:32 PM #17Junior Member
- Jun 2012
- Newburgh indiana
If it lean on bank 2 then it sounds like a stuck closed injector
2002 tahoe 5.3L CAI, tr224 112lsa cam, ls6 springs, 10.4mm plug wires, monster trans stall converter 2,300-2,500 rpm, cat delete, flowmaster exhaust, custom tune by wayne hartwig
06-10-2012, 04:27 PM #18
All of the fuel trims read normal when on the diagnosis reader at the shop on Friday. i'll have to go buy one I guess. I don't want to drive it in the event I cause more issues.
06-10-2012, 04:48 PM #19Junior Member
- Jun 2012
- Newburgh indiana
Switch the injector to the other bank an see what happens
06-10-2012, 04:56 PM #20
Trans am running bad getting a po308 misfire code on bank 8
By Street Fighter in forum General HelpReplies: 3Last Post: 02-27-2016, 04:05 AM -
Help: Engine running very very poorly - ideas?
By cullywoo in forum General HelpReplies: 28Last Post: 09-05-2012, 09:57 AM -
Need help with lean codes bank 1&2
By Ieatstangs in forum General HelpReplies: 14Last Post: 05-13-2012, 07:28 PM -
'97 LT1 running poorly...
By LT4Hawk9 in forum LT1Replies: 1Last Post: 07-29-2010, 12:58 PM -
Help: Z28 Running Poorly
By cm86414 in forum General HelpReplies: 10Last Post: 05-28-2009, 05:52 PM
