Results 1 to 15 of 15
    Member Ieatstangs's Avatar
    Feb 2008
    Bay Area :(
    blue
    99z28 a4
    Need help with lean codes bank 1&2
    My 98z28
    Is throwing lean codes for bank 1 and 2
    I have Mac mids no cats and a bbk intake
    Could these code be from the absence of the cats or do I need to look elsewhere
    During the install I demolished my hose from the back of intake to the Pcv valve I replaced it with what I could. Find
    The fuel filter is less than 6 months old
    01 black SS with a few slp options
    Stock MAF? Did you replace the O2 senders? Any exhaust or vacuum leaks? Have you checked you fuel pressure?
    Feb 2008
    Bay Area :(
    blue
    99z28 a4
    Yeah the maf is stock no exhaust or vacuum leaks that I found so far no I havent check fuel pressure im kinda scared to
    The O2 senders are tight in the headers? Any other codes being set?
    Unless the engine is ingesting unmetered air, ie. a vacuum leak, or there is air leaking into the exhaust system above the O2 senders, then the problem may very well be fuel pressure. It's easy to check and most chain parts stores now have a "rent-a-tool" service if you do not want to buy a gauge. You should have 58 p.s.i. at the rail.
    Feb 2008
    Bay Area :(
    blue
    99z28 a4
    Thanks I kno how to do it Im jus scared of the results lol
    That I understand. Good luck!
    Feb 2008
    Bay Area :(
    blue
    99z28 a4
    I jus checked for vacuum leaks wit some carb spray but no drop in idle anywhere my air lip wasn't closing properly fixed that I'm gonna clear the codes n go enjoy a day at the beach n deal wit this tonight thanks for the advise
    The PCV system, especially the rubber fitting at the throttle body, is usually a prime suspect for a vacuum leak.
    Feb 2008
    Bay Area :(
    blue
    99z28 a4
    If it was leaking and I sprayed it with carb cleaner the idle would drop ?
    I hope the intake isn't cracked but when I sprayed around it no change in idle
    I doubt the intake is cracked. Usually it is a hose, exhaust gasket, or a crack or leak in the exhaust tubing. The PCV hose runs behind the engine and over to the back of the driver side rocker cover. A couple of members have had them fail in the back where the problem can not be easily discovered. Did you reset the code and drive the car?
    Feb 2008
    Bay Area :(
    blue
    99z28 a4
    Yeah I reset the codes they came back .... Do u mean the hose from the brake booster ? I tried spraying in the back the hose was wet and eventually dried ....
    The PCV hose assembly looks like this (left side goes to throttle body, right side to vent hole on driver side rocker cover):
    Feb 2008
    Bay Area :(
    blue
    99z28 a4
    How much do these run in the event that this is my issue
    You don't want to know... around $150 if I recall. Better to make your own as you really can't see any of it.
    Feb 2008
    Bay Area :(
    blue
    99z28 a4
    $150 isn't horrible if it'll make my car run better and I have a buddy at gm who gives me wholesale price
  1. The Never Ending Lean Bank 2 Saga........
    By jfl330 in forum General Help
    Last Post: 08-14-2013, 09:24 AM
  2. P0174 Lean Bank 2 Code (forever...........)
    Last Post: 11-20-2012, 05:49 AM
  3. Help: Lean Air bank 1 and 2 codes (P0171, P0151)
    By MeanGreen98 in forum General Help
    Last Post: 01-24-2012, 05:17 AM
  4. Throwing codes for bank 1 and 2 being lean.
    By !!!FAST!!! in forum External Engine
    Last Post: 08-14-2010, 07:06 AM
  5. Problem with one cylinder bank going lean.
    By Sam-SS in forum Computer & Tuning
    Last Post: 11-01-2007, 07:13 AM
