Thread: Driverside window problem
06-03-2012, 11:34 AM #1Junior Member
- Jul 2006
- PA
red- 2000 Trans Am WS6 Package
My driverside window will go down then won't go back up, have to wait a few minutes then it starts and stops again. I heard about the window motors going out but when it stops moving and I try the button up and down I hear a buzzing noise under the dash about the center of it. Gonna try and find where the noise is coming from, but until then any opinions and thoughts would help. Thanks
06-03-2012, 01:28 PM #2Your friendly policeman
- Jan 2012
- Alabama
Bright Rally Red- 2001 Chevy Camaro Z28
I think the noise you are referring to is the express down module. Sounds like your motor is overheating. There is a write-up online somewhere regarding rewiring the motor to prevent it from overheating and cutting out on you. Here is a write-up on replacing the power window motor. It also explains some of the issues you mentioned.
Power Window Motor
06-03-2012, 01:32 PM #3Junior Member
- Jul 2006
- PA
Thanks, I will check it out.
06-03-2012, 02:49 PM #4Junior Member
- Jun 2012
- Bradenton FL
Red- 2002 Pontiac Trans Am
its probally your window motor be careful what motor you use. GM is now using china motors in there delco line. Dorman has motors made in the US Advance Auto carries them. make sure you look in the box before purchasing to see where the motor was made.
06-03-2012, 03:11 PM #5Your friendly policeman
- Jan 2012
- Alabama
I'll also add that the Dorman motors carry a lifetime warranty and cost approximately $50 at Advance Auto. I replaced my passenger-side window motor about 2 months ago.
2001 Chevy Camaro Z28 A4
SLP cold air intake/lid, SLP smooth bellow, Pacesetter LT's, ORY, Magnaflow exhaust, BMR STB, adjustable Panhard rod, SFC's, LCA's, 1LE sway bars, cross-drilled rotors
06-03-2012, 04:43 PM #6Junior Member
- Jul 2006
- PA
Thanks guys. Might try the jumper trick with the bigger wire, see how that works.
06-05-2012, 09:30 AM #7
Driverside window
By "2000 WS6" in forum Firebird / WS6Replies: 0Last Post: 06-03-2012, 11:29 AM -
93-02 Camaro driverside outer window weatherstrip
By 9t8z28 in forum Parts Wanted / TradeReplies: 0Last Post: 10-06-2009, 06:45 AM -
window problem
By blackz28ls1 in forum General HelpReplies: 6Last Post: 08-03-2008, 07:43 AM -
Question: Power window (driverside)2001
By James2001RAMAIR in forum Firebird / WS6Replies: 7Last Post: 05-10-2008, 08:44 PM -
driverside window?
By FastAssZ in forum General HelpReplies: 6Last Post: 03-08-2006, 10:47 AM
