    OC, California
    1999 Z28 M6
    driverside window?
    alright im having problems with my drivers side window, the passenger is fine just slow but the drivers is weird. sometimes it will work fine and others it will roll down half way then stop and then you have to wait for it and then it will go another 2 inches and another and another, its like you have to wait for it to recharge or something, is this the motor or something else?
    Member Thewilldog's Avatar
    Jacksonville, FL
    2001 Z28
    Look at the sticky thread about 3 inches above this post "How to install a power window motor." Well known issue w/ Fbodys.
    OC, California
    1999 Z28 M6
    yes i kno how to replace it thank you, but my question is, is it the motor or something else such as a bad wire or ground? when it stops, ill push the button up and down to see if it will go and it will make a noise that sounds like its commin from behind my front gauges, is that a common thin to happenw hen the motor goes out or is this something else?
    Member mikeaford's Avatar
    Fredericksburg Va
    01 Trans Am
    I know when mine went out same thing would go down a few inches stop then a little while later it would go another inch or so but never noticed a noise probably because car was running. Replaced the motor VOILA up and down it goes. Hope my experience helps you.
    OC, California
    1999 Z28 M6
    yes thanks, now i know its just the motor n not something else, thanks dude
    Houston,Texas
    same thing happened with my current 2000 Z28 that happedned in my 1997 Z28 4 years ago. with the 97 it was the switch, this time it was the motor
    Member jmhvenom's Avatar
    Cincinnati, OH
    2002 Z28
    i had the problem under warrenty, they said they replaced the regulator, but i think it weas just the motor.
  1. Driverside window problem
    By "2000 WS6" in forum General Help
    Last Post: 06-05-2012, 09:30 AM
  2. Driverside window
    By "2000 WS6" in forum Firebird / WS6
    Last Post: 06-03-2012, 11:29 AM
  3. 93-02 Camaro driverside outer window weatherstrip
    By 9t8z28 in forum Parts Wanted / Trade
    Last Post: 10-06-2009, 06:45 AM
  4. Camaro Front Driverside inner fender
    Last Post: 06-08-2008, 06:12 PM
  5. Question: Power window (driverside)2001
    By James2001RAMAIR in forum Firebird / WS6
    Last Post: 05-10-2008, 08:44 PM
