Results 1 to 10 of 10
Thread: Dyno numbers! Post 'em up!
05-08-2012, 05:01 PM #1Your friendly policeman
- Jan 2012
- Alabama
Bright Rally Red- 2001 Chevy Camaro Z28
I remember when the LS1 was a fairly new powerplant in the F-body there was considerable debate whether or not GM had actually underrated the claimed factory power ratings in the V8 F-body. So, does anybody have any dyno sheets to back up the claim that the numbers GM claimed were lower than the actual output of the factory (read STOCK) LS1? If so, post 'em up!
2001 Chevy Camaro Z28 A4
SLP cold air intake/lid, SLP smooth bellow, Pacesetter LT's, ORY, Magnaflow exhaust, BMR STB, adjustable Panhard rod, SFC's, LCA's, 1LE sway bars, cross-drilled rotors
05-08-2012, 05:46 PM #2
There is a sticky on this and elaborate spreadsheet of all the members rides and add-ons with numbers in the DYNO forum section. Check it out!
05-08-2012, 05:48 PM #3
ALso, dont try to compare one are to another if they are not on the same dyno on the same day.
05-08-2012, 06:25 PM #4Your friendly policeman
- Jan 2012
- Alabama
Crap....oh, well
Originally Posted by 35th-ANV-SS:2774167
05-08-2012, 06:31 PM #5
I have a 1998 issue of Motor Trend and they got 286-ish out of the Formula and Z28......both 6-speed cars. The Mustnag Cobra was like 260-ish. I can look it up if you want.
THey range anywhere from 280-320. Different dyno, different days, people can make them read what they want.
05-08-2012, 06:38 PM #6Your friendly policeman
- Jan 2012
- Alabama
I wasn't so much looking for comparisons between cars as much as I was wanting to compare owner's stock LS1's to GM's factory rating.
Originally Posted by TLS_Addict:2774168
05-09-2012, 07:02 AM #7
Mines a factory freak. 400hp to the wheels. Stock.
And then I woke up.
05-09-2012, 09:16 AM #8Consumer of kraut
- Dec 2006
- Jenks/Tulsa
Light Pewter Metallic- y2k 8-cylinder catfish
Of course they were underrated. It's the same engine as the LS1 Corvette (which was rated at 350hp). They rated flywheel power for the Corvette, as that is the flywheel rating for the LS1 in general. They're not going to advertise the LS1 fbody the same as they would their flagship sports car, the Corvette. I've only dynoed my car once back when it was only a lid and catback with factory y-pipe and it did, I believe, 290 to the wheels.
05-09-2012, 09:34 AM #9Senior Member
- Apr 2010
- Alpharetta, Ga
04 Cobra 'vert - M6 mysti- 02 WS6 coupe - A4 red
373 rwhp and 365 rwtq... on my Cobra...
that's the only car I've put on the dyno so far...
05-09-2012, 10:10 AM #10
My 02 SS M6 made 330/342 on a Mustang DYNO with just headers, lid and exhaust. That was also through a 9" rear end which is one of the least efficient.
Post your Dyno numbers!!!
By powermad in forum Dyno InformationReplies: 367Last Post: 06-23-2009, 04:56 AM -
First dyno numbers...
By maxpit in forum Western MembersReplies: 101Last Post: 10-29-2008, 08:14 AM -
Tr230 dyno numbers 98 heads=bad numbers?
By phoenix1987 in forum Dyno InformationReplies: 7Last Post: 09-11-2007, 08:33 AM -
New Dyno Numbers
By JD_Z28 in forum Western MembersReplies: 65Last Post: 04-04-2007, 08:04 PM -
DYNO numbers
By Brad5150 in forum Firebird / WS6Replies: 2Last Post: 01-20-2007, 07:29 PM
