05-02-2012, 04:29 PM #1**Te@M fBoDy**
- Nov 2010
- The Woodlands,Texas...N.O.
Pewter Metallic- 2000 Pontiac Trans Am WS6
BAER or High Performance Brake Calipers For T/A
are baer brakes available for 93-02 trans ams? i like how the high performance brake calipers look even the CTS V with the LS2 engine brake calipers look great i want that look on my t/a
a set of these in red will look great on any 4th gen fbody
05-02-2012, 05:58 PM #2Senior Member
- Aug 2007
- Greensboro, NC
Pewter- 2002 Trans Am WS6 M6
You can put the cts-v brake setup on your car as long as you have 18 inch wheels. Wesman has a writeup on it somewhere on here.
05-02-2012, 07:45 PM #3
05-02-2012, 08:02 PM #4Senior Member
- Oct 2008
- Coral Springs, Fl
I've got 4 piston rear willwoods, No fronts though
05-03-2012, 05:13 AM #5
Yes, Baer Brakes are available for the Fbody cars but they are pricey for the system.
The Baer Claw system will run you about $3000-$3500, without new rear calipers (only "enhanced" ).
You can get the Eradispeed 2-piece rotors for the front and the 1-piece Decelarotors for the rear for about $700-$850. And get some Hawk HPS pads, stainless brake lines and paint your calipers and it would be cheaper.
Have you seen the ATE Premium One rotors and packages from stranoparts.com? I've never heard anything bad about them.
Sent from Motorola Atrix using Tapatalk 2.Last edited by BadTA00; 05-03-2012 at 05:15 AM.
2000 T/A-DMH Cutout, SLP Cold Air kit, FTRA/SLP Upgrade, SLP Bilstein, LT1 Eibach ProKit, Kuhmo PA31 Tires ,SLP Fan Switch, UMI Double Adj PHB w/ Roto-Joints, UMI LCARB, Strano 35/22mm Sway Bars , Magnecor KV85 Wires, Hurst Shifter, Lou's Short Stick.
05-06-2012, 11:17 AM #6
While we are on the subject... is there a reasonably priced caliper upgrade that will fit the stock wheels?
05-06-2012, 02:02 PM #7Senior Member
- Oct 2008
- Coral Springs, Fl
I know you can do the c5 upgrade that pushes the caliper outwards so you can fit c5 rotors, not sure about calipers though. I'm most likely going to pick up some stainless lines, sounds like a decent upgrade.
FS BAER CLAW GT PLUS Brake Kit (NEW)
By fast droptop in forum Parts For Sale / TradeReplies: 4Last Post: 05-14-2009, 09:22 PM -
Question: baer brake grinding
By joker in forum General HelpReplies: 9Last Post: 02-11-2009, 10:50 AM -
Baer Brake Kit and Wheel clearence
By LS1 Eddie in forum General HelpReplies: 3Last Post: 12-09-2005, 06:41 AM -
Baer brake rotors for 98-02 f-bodies
By 98-LS1 in forum Wheels and TiresReplies: 8Last Post: 12-07-2005, 05:48 PM
