10-19-2005, 05:25 AM #1Hemi Destroyer
- Oct 2005
- Knoxvegas, Vol country Tennessee
Sebring Silver- 98 Z-28 camaro
Baer brake rotors for 98-02 f-bodies
FYI: O-Reilly auto parts has Baer slotted and cross drilled rotors for our cars for the price of $90.00 a piece for the fronts. That's a better price than powerslot or any other brand, now I haven't ran them yet but I just found out about it so I thought ya'll might like to know. They do have to order them but it's only a day or so for shipment.
98-LS1
10-24-2005, 10:18 AM #2Member
- Sep 2005
- Cincinnati, ohio
black- 1999 Trans Am
Thanks for the info, let us know how they work out.
10-26-2005, 12:55 PM #3
I have the Baer Eradispeed slotted/cross drilled rotors at all four corners, with Hawk pads. Bite like a M.F. when warm. A little bit noisier than stock though.
10-27-2005, 04:19 AM #4Hemi Destroyer
- Oct 2005
I'm going to pick these up next week, for ninety bucks that's hard to pass up
11-03-2005, 06:00 PM #5Junior Member
- Stratford, NJ
Fire Red- 2000 ws6 #599 9/20/1999
just a little info, if you use the eradispeed plus rotors and a set of bendix titanium3 ceramic pads, they stop amazingly well, make hardly any noise, and have practically no dust.
11-04-2005, 12:12 AM #6
Has anyone purchased the cross drilled/slotted rotors off of E-bay? I have noticed the prices are kinda cheap just need to know if rotors are too. Didnt notice any popular brands. Thanks
11-12-2005, 01:40 AM #7
You really have to watch the cheaper rotors - especially the crosdrilled versions. Most of the cheap crossdrilled rotors are just standard rotors that someone drills. On top of that, they are more than likely mfg. in Mexico from inferior metal/casting process.
The crossdrilling should actually be cast into the rotor and in very specific areas as to eliminate crack propegation.
The brake system is definitely NOT an area where you want to scrimp on $$ if changing from stock.
If you're just looking to buy slotted/crossdrilled due to the looks, and don't want to spend $$, then they are really not for you.
If you want to go with just slotted - the Powerslot rotors are a very nice/quality part and are not too expensive...
I run the Baer GT+ system on my WS6 with the larger PBR calipers, Eradispeed front 2-pc rotors that are both larger in diameter/thickness, and the Eradispeed rear rotors. All are crossdrilled/slotted. Cost was $1500 on sale
-Jay-2000 Phoenix WS6 Trans Am
Pride of Western PA Car Shows
426RWHP/418RWTQ N/A (Mustang Dyno MD-1750)
584RWHP/510RWTQ Massaged by TNT (Mustang Dyno MD-1750)
11-13-2005, 04:39 PM #8
Thanks for the info. My fronts are slightly warped. I just got the 18" Z06 wheels and the rotors are very visable. So i thought i would just get a set of crossdrilled rotors mostly for the looks. How much are the rotors alone? (stock size of course)
12-07-2005, 05:48 PM #9Junior Member
- Nov 2005
- Sedalia, MO
silver- 2000 WS6
O'reilly can get eardispeed rotors slotted and drilled for 90 bucks piece is that the same ones on ws6store.com? the are like 500 for all four on there
