    Member importssuck's Avatar
    IL
    MAP sensor location
    On the LS1 engine where exactly is the MAP sensor located?
    Member xssv's Avatar
    Sep 2010
    Michigan
    01 SS
    Quote Originally Posted by importssuck View Post
    Plugged in directly behind the intake....
    Just a heads up -- be careful when you go messing around back there, especially if it is on an F-body. The oil pressure sender is also back there on the driver side and can be easily broken.
    Member cowstandmoto's Avatar
    Houston, Texas
    Dark Blue Metallic
    2002 Trans Am WS6 M6
    Yep! Jeff is right. You do have to be careful back in that area. A couple of my buddy's have broken the sending unit right off. The MAP is located on the intake, on the back left portion of the intake. And the oil sending unit is mounted on the valley cover, in the back center, behind the intake.
  1. Question: trans temp sensor location?
    By 383ls6 in forum Automatic Transmission
    Last Post: 01-05-2012, 11:27 AM
  2. Oxygen Sensor wire location
    By bostonbruins34 in forum General Help
    Last Post: 01-19-2011, 03:58 PM
  3. Oil Pressure Gauge Sensor Location
    By FOXBAT in forum General Help
    Last Post: 01-23-2008, 07:01 AM
  4. ECT sensor location? DTC P0128
    By Eagle in forum General Help
    Last Post: 05-30-2007, 09:08 AM
  5. O2 sensor location names
    By grandkodiak in forum LT1
    Last Post: 01-31-2007, 10:24 AM
