04-19-2012, 01:28 PM #1Junior Member
- Jan 2012
- TN
replaced knock sensors but still have light
Just got through replacing new knock sensors and harness.Re-connected battery and drove about 7 miles,then service engine soon light comes back on.Took it back to Auto Zone,scanner said knock sensor again,but this time it said low input 1 & 2.Auto zone cleared it with there scanner but light re-appeared about another few miles.Think I might of got some bad sensors?I purchased them off ebay.Those of you who have done this know how time consuming it is to do this job.Think hard about what I should do?Thanks in advance,Andie.
04-19-2012, 05:18 PM #2
I would shy away from an ebay sensor and install GM sensors. Any chance you pinched the KS wire harness upon installation of the intake?
04-19-2012, 07:00 PM #3None Shall Pass
- Jan 2010
- East of Cleveland, Ohio
Black- 99 WS.6 - Modified
Agree with Jeff's suggestions. Also, are you sure you aren't actually getting a knock? Why did you replace the last set?
04-19-2012, 07:45 PM #4
what brand and part number of sensor did you use? I agree with the other guys......it's easy to pinch that harness putting the intake back on. I also think pulling the intake on these cars is a pretty quick and easy job. Once you do it a few times you get much faster at it.
04-19-2012, 07:58 PM #5
Could be a bad wire to the computer..
This happend to me. I replaced the KS, knowing I dont have a knock bc its a brand new engine.. Still had the code, so replaced harness.. Still had code. Had to get it rewired all the way to the computer..
04-19-2012, 08:16 PM #6Junior Member
- May 2009
- Santa Maria, California
Black- 1998 Pontiac Formula LS6
I had to deal with this same problem last Dec. For right now the easiest test you could do would be to disconnect the KS harness and verify you have 1000 ohm resistance on both leads. If you have 0 resistance you know you probably pinched the harness somewhere. This test will give you a good idea which direction to go next.
04-21-2012, 06:14 PM #7Junior Member
- Apr 2012
- South East Georgia
BLACK- 1998 WS6, ASC BUILD #206
You probably do not have the same issue I did BUT, my SES light started and would not clear more than a couple miles.
Computer showed it was a sensor located underneath back near the gas tank.
We ordered a new sensor and when we started to replace it, we discovered a "RAT" had chewed into the wire and pretty much had it disconected on one side.
Regardless, I had the new sensor so it was installed, the chewed wire was re-connected and that fixed my SES situation.
Bottom line, look for wires that may be chewed into or in half.
04-21-2012, 08:19 PM #8
Yes, the job of r and r ing the intake seems daunting the first couple of times, but you get quicker at it. I did. Seriously, I would suggest that you pinched the wire harness.
04-21-2012, 09:31 PM #9Junior Member
- Jan 2012
- TN
I bought the sensors off ebay because they were GM.There's a good chance that brand new harness wire got pinched because I was so disgusted after seeing how GM laid that wire ontop of that valley tray to cook,I simply used some thick braided wire and glued back over to protect from heat.There was a pretty big hump left where that wire goes over middle tubing.The motor is running smooth as all get out tho.I'm no mechanic,but I did everything else by book including torqing right.I think all the oil in the intake would give any stock LS1 a knock.
04-22-2012, 08:17 AM #10
Catch can next!
04-22-2012, 05:01 PM #11Spaz is My Mentor
Did you get KS for a 98 or 99< ?
There is a difference. The >98 KS have been phased out of GM's inventory.
To use 99< KS you will need a 99< wire harness. Not much about $35.
The new KS have less potential to give off false reporting of knocking.
Also I used some masking tape to hold my wire harness in place in the VCT. I learn this important step because I pinched the WH while installing my LS6 intake.
04-23-2012, 12:33 AM #12
You can also get knock from over torquing the sensors down or using pipe tape on them.
2010 Camaro SIM 2SS/RS A6
1999 TA A4 NBM
12.265 at 110.52mph
knock sensor code with new knock sensors?
By zaaronz in forum General HelpReplies: 13Last Post: 02-27-2011, 06:26 AM -
Knock Sensors?
By SMWS6TA in forum General HelpReplies: 13Last Post: 12-17-2010, 05:42 AM -
Question: `98 T/A knock sensors
By ls1robert in forum Firebird / WS6Replies: 6Last Post: 08-01-2010, 01:51 PM -
Replaced all o2 sensors still thows code for all 4
By blu98ls1 in forum Computer & TuningReplies: 20Last Post: 12-31-2009, 03:14 PM -
knock sensors
By David Ray in forum General HelpReplies: 2Last Post: 08-18-2009, 04:14 AM
