Thread: `98 T/A knock sensors
07-31-2010, 12:50 PM #1Junior Member
- Sep 2009
- Detroit
Blue- 1998 Trans Am
okay i have a `98 T/A and when i first got it i already started to mod it...headers/exhaust wires, plugs, NOS, ram air raptor hood, 160 thermostat, 3.73 gears, eibach springs....well anyways at the time when they came out with the LS1 the factory didnt know that the knock sensors were garbage and when i put the strut bar, sub frame connectors and roll bar in the car was stiff and still is w/ the same mods but those knock sensors ROB me of power like crazy and i can tell becuz the vibrations retard the timing of fuel and blah blah blah...My car ran 11.7 @ 133MPH when they didnt bang....after `98 they replaced them and put new ones in the T/As cuz they sucked...i wanna replace mine wat do i do?? get 1999 knock sensors or what cuz i want all my power??
07-31-2010, 05:14 PM #2
There's a few things to help the stock replacements. I used 3M self adhesive 1/4" foam inside the sensor holes to help muffle the noise & they can be tuned out some with HP tuners or if you have a tuner, they can turn the noise levels down.
07-31-2010, 05:25 PM #3
you can upgrade your sensors and harness to a 99+ which is what I did. Still didn't solve my problems completely so I desensitized them with tuning which helped some more. How much KR are you seeing? It also pulls spark timing and not fuel.....just so you're aware.
Also, are you 100% that it's false knock and not real knock? Knock on spray can end in a very bad way. I would make sure your'e not a little lean or running too much timing on the juice. How much timing are you running and how big of a shot?
08-01-2010, 10:26 AM #4Junior Member
- Sep 2009
- Detroit
Blue- 1998 Trans Am
well when i rev it and hold it at 1600 RPM the car vibrates alot and its noticable so im guessing its real and i took my juice out a year ago and isn't going back in. I want to absolutely eliminate KR because my car isnt running peak obviously. I want to find a way so my car can run 100% please help
08-01-2010, 10:29 AM #5
08-01-2010, 12:33 PM #6Junior Member
- Sep 2009
- Detroit
Blue- 1998 Trans Am
08-01-2010, 01:51 PM #7
how many degrees of timing are they pulling? My point is unless you know for sure what's going on you're just guessing at the problem. Since you have a 98 you may have the standard 3 degrees that they like to pull but 3 degrees wouldn't even be noticeable seat of the pants wise and won't make the car vibrate.....I'm still going with a miss which could be plug/wire related or fuel related.
You will be a step ahead of the game to find someone that can log the car and see what's going on.
Question: Knock Sensors
By Keith01 in forum General HelpReplies: 8Last Post: 07-27-2011, 10:58 AM -
Knock Sensors
By My00Z28 in forum General HelpReplies: 22Last Post: 07-14-2011, 11:01 AM -
knock sensor code with new knock sensors?
By zaaronz in forum General HelpReplies: 13Last Post: 02-27-2011, 06:26 AM -
Help: knock sensors
By bpopham22 in forum Firebird / WS6Replies: 11Last Post: 03-10-2010, 08:12 PM -
knock sensors
By David Ray in forum General HelpReplies: 2Last Post: 08-18-2009, 04:14 AM
