    Throttle body swap
    How hard is it to swap throttle bodies?? I mean after i pull the lid off as one peice what else has to be done. and how do u disconnect the throttle cable. How long will the swap take?? And is this a good mod.
    Local Idiot Selah's Avatar
    Wilmington, De
    Cyclone Grey Metallic
    2005 GTO
    If you don't have either, Forced induction, a stroker or a big ol' cam, i would put the money elsewhere. LS1 TB's are pretty big stock, and will hold alot of power.
    I Love My Bong easyericvan's Avatar
    Hot Springs, AR
    Midnight Blue
    99' Trans Am
    Its pretty easy. You lift the throttle cable up and it should pop out. Then just unbolt throttle body, but make sure you don't get any dust or other crap in the engine while swapping them.
    Member Transcoupled's Avatar
    Las Vegas, NV
    Maple Red Metallic
    2000 Poctiac Trans Am-A4
    Its easy, I used the instructions from www.installuniversity.com. Piece of cake!
    Roseville, CA
    05 Wrangler
    00 Z28 sold :-(
    it's pretty simple....pull everything that's hooked to it off with a rag under it to catch coolant. Put new one on and hook all the hoses and throttle/cruise cable back on....
  1. Swap an f-body rear end into a G-Body car
    By Carmine lucchese in forum Firebird / WS6
    Last Post: 09-07-2016, 01:38 PM
  2. Help: LS1 Throttle body
    By 2002ssslp in forum General Help
    Last Post: 07-18-2011, 03:36 PM
  3. Throttle Body
    By ledesma54 in forum GTO
    Last Post: 06-04-2008, 03:56 AM
  4. 98-02 stock LS1 f-body throttle body
    By noblesramair in forum Parts Wanted / Trade
    Last Post: 03-04-2006, 05:59 PM
  5. 4.8L Truck throttle body swap
    By speed01rcr in forum External Engine
    Last Post: 10-23-2005, 02:09 PM
