    Member flybird's Avatar
    Jun 2010
    Houston
    Mid Night Blue
    1999 Firebird 3.8 series
    Quick question, pilot bearing
    Im looking at a car to buy, but the guy replaced the clutch that now has 7k on it but he didnt replace/ grease the pilot bearing. So clutch makes a lil noise due to that.
    Is this bad? I am not familiar with this so I am asking you guys!
    how much would it cost (ESTIMATE) to fix this problem?
    Thnx guys!
    Coral Springs, Fl
    Sunset Orange Metalic
    Trans has to be removed, possibly 300, all labor
    sure thats the problem?
    Jun 2010
    Houston
    Mid Night Blue
    I believe so, has 109 k ; clutch 7k; he claims thats the problem.. I havnt test drovd the car yet, he said it only makes noise when clutch is disengaged.. ??
    Jun 2010
    Houston
    Mid Night Blue
    EDIT: it makes a clunk noise when clutch is disengaged. This is what he has told me.
    Coral Springs, Fl
    Grinding noise at all?
    Jun 2010
    Houston
    Mid Night Blue
    Ill find out thursday once I look at it.
    I believe this guy knows what he's talking about , he is a mechanic at planet ford, I told him after the test drive if I like it, he will replace pilot bearing himself and ill make up the diff.
    We'll see how deal goes down. I just wanted to see what yall think.
    Veteran 35th-ANV-SS's Avatar
    Wherever life takes me
    02 35th LE Camaro SS
    A bad throw out bearing could make a noise like that.
    Pittsburgh
    2008 Hummer H3
    Yes,, I would think that as well before I'd think pilot bearing, unless the pilot was damaged during install.
    IIRC, most/many clutch kits come with a pilot bearing don't know why they would'nt replace it while in there.
    Least that's my take on it anyways.
    Good way to tell if the pilot is shot is check for trany leakage around the input shaft. If it's leaking stay away imho.
    An egged out pilot bushing or damaged needle bearing type can put stress on the input shaft.
    That kind of side deflection can stress everything it's associated with inside the trany. Not good.
    Jun 2010
    Houston
    Mid Night Blue
    Thnx for the input guys. Ill be doing a full on inspection/diagnostic on the car. (besides the non-catted x pipe hoping everything else is fine)
  1. Throw-out bearing or Pilot Bearing going out? Need help.
    By werewolf in forum Manual Transmission
    Last Post: 04-11-2013, 05:19 PM
  2. Question: Pilot bushing or bearing?
    By lsgunner28 in forum Manual Transmission
    Last Post: 07-27-2010, 08:34 PM
  3. Does it take a genius to get out my pilot bearing?
    By getcha01 in forum Manual Transmission
    Last Post: 02-06-2009, 03:55 PM
  4. Damn Pilot Bearing
    By reils1 in forum Manual Transmission
    Last Post: 05-10-2008, 04:15 AM
  5. Pilot bearing question
    By hissin'98 in forum Manual Transmission
    Last Post: 10-12-2005, 06:18 PM
