03-23-2012, 01:18 PM #1Junior Member
- Mar 2010
- San Jose, CA
Red- 2002 SS Camaro Convt
My 02 ss Camaro idling ruff and feels like turning off
Any advice would help.. My camaro is a A4 with 95k miles.. Has Slp lid, no cats, kooks long tube headers, 3" exhaust, not cammed... I just changed new sparkplugs (AC delco irridium), MSD Wires, front 02 censors,Maf censor and still idles rough.. There's a sound coming from the engine bay thats sounds like a lifter or lil knock.. Car runs good on the freeway, has heat...
03-23-2012, 03:57 PM #2None Shall Pass
- Jan 2010
- East of Cleveland, Ohio
Black- 99 WS.6 - Modified
What MAF did you install? GM or aftermarket?
And how did you replace the front O2s? Did you splice the wires or get the full length wire harnesses?
You might also check to ensure the spark plug wires are firmly connected at the plugs and coils, and the coil plug connector is attached.
03-23-2012, 04:36 PM #3Former Mopar Man
- Jun 2011
- Branchville, NJ
The sound from the engine bay is normal in most cases, just LS1 piston slap. Otherwise I would look into the MAF and O2. Never splice wiring to a sensor and aftermarket MAF meters are not the way to go. The stock Delphi unit is good to 500 hp and it is what the factory intended for that car. Did you change the tune in the computer ?
03-24-2012, 02:13 PM #411 years of bangin gears
- Jan 2009
- North Jersey
I agree with the posters above. Also with re-checking your wires. Some could be loose. Are you getting any codes?
03-25-2012, 02:05 AM #5
I assume it was idling rough and that's why you replaced all the parts or was idling rough before?
03-25-2012, 04:02 PM #611 years of bangin gears
- Jan 2009
- North Jersey
No cats, eh? Has the car been tuned?
Help: 2000 Camaro Won't Align After Turning Left
By jasonduaine in forum Suspension and HandlingReplies: 4Last Post: 04-23-2016, 02:25 PM -
Help: A4 camaro turning off problem!?!?
By 01SsRacing in forum General HelpReplies: 3Last Post: 09-20-2011, 07:59 AM -
replaced plugs and wires camaro feels sluggish??
By PAT-LS101 in forum General HelpReplies: 6Last Post: 03-02-2009, 08:27 AM -
Cause It feels so empty without me!
By SLIM_DURST in forum Political / Debate ForumReplies: 14Last Post: 09-26-2008, 06:11 AM -
My Camaro idling
By Kamauxx in forum Camaro / SSReplies: 4Last Post: 10-05-2007, 05:46 PM
