09-17-2011, 05:23 PM #1
A4 camaro turning off problem!?!?
My 2001 camaro ss this week twice when I turn the key to start it start but really bad idle like it has a huge cam but it does then it stalls and turns off while its doing the the battary gauge is move back and forth? also while driving sometimes while running radio lights and AC the battary gauge will read unders the 13 volts line. the battary is good the positve bolt was rusted bad but just put a new one in and it did it the frist start up. The car is stock but has all the slp stuff from factory and a smooth bellow and the sensor that come with that.
2001 Camaro SS, LM 1, BMR LCA, relocation brackets, BMR springs, adj panhard bar, smooth below, lid, sub-frame connectors weld on, strut brace
2000 WS6, ls6 intake, sub-frame connectors, slp maf, slp cat delete with slp y-pipe, electric cutout, strut brace, smooth below, slp lid, bmr LCA and RLB
09-18-2011, 03:10 PM #211 years of bangin gears
- Jan 2009
- North Jersey
Have the alternator tested. It might be on its way out. Check the wiring going to the alternator too as there have been members who have had a bad alternator ground wire. Also check to see if the alternator pulley spins freely as it will cause an idle/stalling issue when the bearings start to crap out on you. Keep us posted.
09-18-2011, 04:53 PM #3
Would I have those kind of problems? I just turned over 35k miles
09-20-2011, 07:59 AM #411 years of bangin gears
- Jan 2009
- North Jersey
It can happen at any time.
Help: 2000 Camaro Won't Align After Turning Left
By jasonduaine in forum Suspension and HandlingReplies: 4Last Post: 04-23-2016, 02:25 PM -
My 02 ss Camaro idling ruff and feels like turning off
By Anayalator408 in forum General HelpReplies: 5Last Post: 03-25-2012, 04:02 PM -
Help: Turning problem
By Lucky1963 in forum General HelpReplies: 1Last Post: 12-05-2010, 02:41 PM -
turning signal problem
By slpdablueZ28 in forum General HelpReplies: 12Last Post: 03-10-2010, 04:39 PM -
Camaro Problem
By RedManCar08 in forum General HelpReplies: 5Last Post: 05-28-2008, 06:27 PM
