Thread: rear end
    Junior Member darryl_ws6's Avatar
    Nov 2011
    espanola
    01 ws6
    rear end
    Hi everyone.. I have a 01 ws6 I was wanting to put some 4:10 gears in the differential... I was wondering what else I should change or get for the drive train thanx...
    Veteran 35th-ANV-SS's Avatar
    Wherever life takes me
    02 35th LE Camaro SS
    Most, if not all, will tell you to not invest putting money into the stock 10 bolt. The 7.5" is already small and weak. Adding 4.10 gear ratio will make the teeth on the pinion even weaker. You'll likely end up grenading it, especially with any kind of traction.
    I would suggest a 9" or 12 bolt.
    Nov 2011
    espanola
    01 ws6
    The 12 bolt come off what vehicle??
    Member chris1974's Avatar
    Jan 2012
    Houston
    Bright Red
    1998 Firebird Formula LS1
    ^^ +1 Jon speaks the truth!
    Indianapolis
    2000 WS6 6spd Hooker LT
    Quote Originally Posted by darryl_ws6 View Post
    Need a custom fabbed 12 bolt. About $2800 I think. However, many people have lots of miles on the OE diff, and many more have grenaded theirs with stock power. So far, 110k on my OE diff and no problems (yet).
    Jun 2011
    Branchville, NJ
    Silver & Blue
    02 Camaro SS, 04 GTO
    You will likely spend 3200.00 or so by the time you are done with the swap. The 10 bolt should have never been put under the GTO, SS or WS6. I like the S60 but it is a little heavy. The 9" is the most popular and the 12 bolt would be the cheapest. Good luck with the swap.
    price has gone way up on those.....I haven't priced one in a long time but when I bought mine I think mine was $2200 shipped.
    May 2010
    Wilkes-Barre, PA
    Black/Black
    98 WS6/04 Sierra Dmax
    I did an S60 in December, $2,400 shipped to my door. You will need to shorten you stock driveshaft with the S60 or just order a chrome-molly shaft from Strange ($300) I went with the Strange driveshaft.
    Member flybird's Avatar
    Jun 2010
    Houston
    Mid Night Blue
    1999 Firebird 3.8 series
    Quote Originally Posted by Too Fast:2757277
    155k and no probs yet either!
    Neither of you are a stick with 4.10 gears either I'm guessing
    Indianapolis
    ^^^ Stick yes, 4.10 gears no. I've thought about that, tho.
    And I always think about getting some DRs, but then I remember my poor little 7.5!
    Jan 2012
    Houston
    Bright Red
    Quote Originally Posted by flybird View Post
    Rebuilt everything BUT the diff!! lmao!
    Just giving you hard time, man.
    OP...I've got 130k on mine with OE diff, and no problems yet. Basically stock LS1 though....
  1. Rear LS1 98-02 Rear Disc Backing Plates/Calipers/Brackets
    By peetsjunkie in forum Parts Wanted / Trade
    Last Post: 10-02-2007, 08:53 AM
  2. Replies: 13
    Last Post: 07-08-2007, 09:42 AM
  3. Replies: 1
    Last Post: 06-19-2007, 07:06 PM
  4. Replies: 0
    Last Post: 05-25-2007, 10:37 AM
  5. Replies: 4
    Last Post: 05-19-2006, 04:39 PM
