Thread: Billet breather
03-14-2012, 05:58 PM #1Member
- Aug 2011
- pittsburgh,pa
navy blue- 1998 camaro ss
Billet breather
Wanted to put a breather in place of my oil filler. 98 ls1! Is there any benifits to this besides looking cool? What if at all will it affect? noticed a little oil in my intake/tb. Pcv is brand new! Thanks
03-14-2012, 06:06 PM #2
The PCV system either needs to be open or closed. With everything left as stock it's a closed system. If you use a breather you need to cap and remove all the lines running to the intake and TB from the valve covers. If you place just a breather and leave everything hooked up you will have a vacuum leak.
03-14-2012, 07:12 PM #3Member
- Aug 2011
- pittsburgh,pa
Is it beneficial in anyway doing that or should I maybe go with a catch can?
03-14-2012, 08:39 PM #4
Running a breather and blocking off the intake and TB from the crankcase is the only way to 100% guarantee that you won't get any oil vapor into the intake tract. But doing this also has negatives. Your oil will get dirty much quicker and you'll have have excess water vapor in the crankcase if you take many short trips and don't allow the engine and oil to fully warm up and burn vapor and containments off regularly. Also depending on how much blow-by your rings have you may get a slight oil smell or mist coming from the breather after high-rpm passes.
A catch can will help pull oil vapor from the PCV system before it reaches the intake and TB but it won't 100% solve the problem. I wouldn't run a breather just because it looks "cool."
03-15-2012, 07:23 AM #5Member
- Aug 2011
- pittsburgh,pa
Aww bummer I just bought one. oh well, guess I have to block everything off. yeah!
Question: breather cap
By JayTA98 in forum General HelpReplies: 26Last Post: 05-19-2011, 08:15 PM -
Breather
By tingo99 in forum External EngineReplies: 11Last Post: 07-26-2008, 08:21 PM -
FRC, WG, Oil Breather
By MECHAM in forum Parts For Sale / TradeReplies: 0Last Post: 11-06-2007, 07:22 PM -
Billet Valve Cover Breather
By WHPLASH in forum Parts For Sale / TradeReplies: 0Last Post: 08-16-2007, 12:07 PM -
This is what BILLET means!! ex: billet flyweels, marketing BS
By ibanez7 in forum General HelpReplies: 5Last Post: 09-22-2005, 03:39 PM
