    Crystal Lake IL
    2001 Camaro Z28 M6
    This is what BILLET means!! ex: billet flyweels, marketing BS
    So many people think, just because its says BILLET, that a billet steel flywheel is this great piece of metal, (thats its super strong or something) or billet aluminum is a hybrid of greatness.
    Thats marketing bullshit!!!
    What does "Billet" mean?
    A billet is a raw block of metal, any type and any grade can be a billet!
    A billet is simply a solid piece of material that is shaped into it's finished form by machining. Most finished products are either cast or molded into shape. A billet is a raw block of material.
    So in other words is just a process of fabrication, let it be done by machineing or by by pushing a solid billet through an extrustion.
    This process does not necessarily mean its stronger or better even though IT CAN BE... Companies only state a part is BILLET because most people dont know what billet means. So in turn a company charges more for the part, since they use the word BILLET for flashieness..
    Rhino21149
    Guest
    Quote Originally Posted by ibanez7
    This process does not necessarily mean its stronger or better even though IT CAN BE... So in turn a company charges more for the part, since they use the word BILLET for flashieness..
    This is a good point. The buyer always must beware. Generally, billet parts cost more partly because machining a shape out of a solid piece of metal is more expensive than just casting it, but also because the piece is often superior in strength.
    An intersting point to ponder is just what "billet" really means to most people. Do you consider something like a FIKSE Profil 5S 3-piece wheel to be "billet?" Each piece of the wheel is made from a separate forged casting, by machining ALL surfaces (i.e., 100% of the surface area of each part is a machined surface). However, the forged castings in each case areroughly shaped like the eventual parts, so there is not too much metal left to machine off.
    But some people would not classify that as "billet," saying instead that "billet machined" means only those situations where the machinist started with a standard-stock piece of metal (say a solid aluminum cylinder, 19" in diameter by 1.5" deep, from which the pieces were cut and machined to make a 18" x 13" wheel). This is what the "billet" catch can sold by MTI is (a beautiful piece by the way): solid stock of AA machined into a beautiful shiny can with fittings).
    Crystal Lake IL
    2001 Camaro Z28 M6
    thank you, someone who understands processes and what Billet means.
    I truely believe there is a huge misconception of the word, which is why I posted this.
    Single Malt rbob93's Avatar
    Ft. Lauderdale, FL
    Sebring Silver
    2000 CamaroSS
    I also like when they they say "billet T6061 aluminum," like it was some exotic.
    Rhino21149
    Guest
    Some people will do whatever it takes to sell their stuff. A lot of marketing is in what you call it and there is a sucker born every minute, as they say.
    I once saw a speed equipment catelog (I won't name which), that listed rolls of duct tape for sale as "Racer's Tape." For $15.95/roll.
    commerce twp michigan
    Casting save a lot of time and money. But they sometimes have voids in them that you may or may not see. Air holes or pockets as meatl is being poured.
    (X-ray the castings. ) You also can make the grain of metal on a billit go on way to make it stonger.
  1. Billet or Cast - Cam ???
    By Eddie 70 in forum Internal Engine
    Last Post: 09-03-2007, 09:04 AM
  2. billet grill
    By vinnie311 in forum Appearance Section
    Last Post: 11-08-2006, 04:35 PM
  3. SS billet grill Q'
    By wicked illusions in forum Appearance Section
    Last Post: 05-25-2006, 06:41 AM
  4. SS billet grill Q
    By wicked illusions in forum Camaro / SS
    Last Post: 05-22-2006, 06:57 PM
  5. Billet Grills
    By smg267 in forum Appearance Section
    Last Post: 04-25-2006, 11:44 AM
