    Senior Member 98maro's Avatar
    Feb 2010
    north bay california
    00 camaro ss M6 #6695
    temp sensor question...
    hi guys, i have a water temp and oil pressure sensor.. how do i wire them?
    they have light and everything but i cant make em work, i connect the wire to the sensor but is not do anything. can some explain me how to do it or post a pic on how the wires go? thank you
    Feb 2010
    this is how my water temp looks like, i put the green wire to it but nothing happens,
    The temp sensor works by varying resistance in correlation to engine temperature. The sender needs a good ground connection to the engine block or head (whatever it is installed in) in order for it to work. As long as your gauge also has power and ground connections, connecting the sender wire should result in a reading. Does it do anything?
    Are you plumbing in a separate oil pressure sending unit, or are you attempting to interface with the stock sender?
    Feb 2010
    sorry for taking long to reply back,,,, thanks for the help jeff,
    im using a separate sending unit for the fuel pressure, on the temp sensor i plug it in but nothing reads, the ground and power are already connected, the signal wire is also connected, im using a sandwich plate adapter on the oil filter for both sensors,
    but still doesnt read anything.. gauge all the way up, then go back to zero..
    cant figure out what im doing wrong
    Check your connections with a DVOM or analog volt gauge to verify power and ground.
  1. 98 Z-28 coolant temp sensor question
    By lsruthles in forum External Engine
    Last Post: 12-15-2011, 03:41 PM
  2. Question: Reading trans temp stock sensor vs aftermarket sensor in pan
    By senicalj4579 in forum Computer & Tuning
    Last Post: 03-29-2011, 07:41 AM
  3. Temp sensor?
    By JwMonE99 in forum General Help
    Last Post: 10-08-2009, 11:15 AM
  4. Temp Sensor
    By bamaz28 in forum External Engine
    Last Post: 02-28-2008, 11:37 AM
  5. Temp Gauge Sensor??
    By M-Ten in forum Computer & Tuning
    Last Post: 11-22-2007, 09:03 AM
