Results 1 to 14 of 14
Thread: UMI parts
    Member 2000dreambird's Avatar
    Jun 2009
    Mass
    silver/black
    00 trans am,SLP,Ws6
    UMI parts
    so im starting to look into a bunch of UMI parts i.e SFC, TA-relocator, LCA relocators.. and so on. my question is should i got bolt on or weld on, and why?
    Senior Member 98maro's Avatar
    Feb 2010
    north bay california
    00 camaro ss M6 #6695
    the only parts you can get weld in, is the subframe connectors, and relocation brackets,
    i have bolt on relo brackets, and weld sub frame connectors.. the reason to weld em is to make it stronger, if you plan on take the parts off in the future, get bolt on, if you dont, weld em in, its worth it in my opinion,,
    Member bouigha123's Avatar
    Mar 2011
    MD
    1999 Formula ws6
    I chose bolt on parts, that way if I ever sold the car I could take them off and sell them to make a bit of extra cash. Also my car is pretty much stock, and low milage so I wanted to be able to remove them and have the car look exactly the same as the day the car left the factory. Either way the parts will make a big difference.
    Very good reasons
    also OP when looking between Box and O tubing, the stronger one is the box style.
    Jul 2009
    North of the Motorcity
    Custom Swirly Black
    2001 WS6 M6
    You can always weld in the bolt ins.
    ^^ This. I also purchased UMI bolt in SFC's for that very same reason. They look great, work perfectly, and the install was quick and easy.
    Member Redrokit8's Avatar
    Aug 2011
    Roseland NJ
    Pewter Silver
    2002 Trans AM WS6
    I took the same advice from Jeff when deciding which way to go on the SFC's. For my purposes it wouldn't be of any benefit to weld them in. I merely wanted to beef up the underneath for touring. You can see by my signature I'm a UMI guy. This past weekend I finished installing SLP tuned Bilsteins and Strano springs. All told, the car is transformed 100% from stock and feels and handles terrific.
    Magnaflow Quad Tip, Lid, SBellow
    UMI: FTC, FSB, RSB, LCA's, PBAR, SFC's, T-Arm w/relo, D/S Loop
    Kooks LTH, 3" YP, H/F Cats
    Custom Grind Cam, Stall, 3:73 rear
    Bilsteins w/Strano Springs Conti Super Contacts
    TuneByFrost MSD Wires
    Cross Drilled/Slotted Rotors w/Ceramic
    Jun 2009
    Mass
    silver/black
    00 trans am,SLP,Ws6
    Very good reasons
    So you would recommend the box style over the 3 point tube style?
    Jun 2009
    Mass
    silver/black
    00 trans am,SLP,Ws6
    also guys thanks for the input, i think i might go bolt on because if for some reason i get rid of the car( which is highly unlikely) i would want to take the stuff off. or maybe one day upgrade to moly or another design
    Jul 2009
    Custom Swirly Black
    2001 WS6 M6
    IMO the 3 point is the best. Especially when matched with a new tunnel brace or torque arm relocation kit. It will tie the front to the back and side to side.
    Quote Originally Posted by 2000dreambird View Post
    Kevin replied best for me.
    Quote Originally Posted by KMdef9 View Post
    Box style will always be better when using same type material. there was a thread a while ago that it was explained the how's and why's. Engineer stuff.
    Jul 2009
    Custom Swirly Black
    2001 WS6 M6
    I recall that thread as well. It has to do with the corners of the box style, which are stronger than the round part of the the umi 3 point. I think it only discussed just box style being stronger than round style, so I'm not sure if I would say 2point box is stronger than 3 point round. Especially if you upgraded the tunnel brace and welded it all together, virtually connecting the driverside front to passenger rear through a web of metal. I would see that as the strongest setup (chrome moly if you must), but that isn't needed for everyone and depends on yours goals too. If you only plan on mild to moderate engine modification and not drag only, then the 2 point box would be fine. I also am not sure where the weight addition will catch up with you because 3 point with a tunnel brace weighs probably twice as much.
    3 point umi bolt in is the most popular sfc on this site.
    Veteran 35th-ANV-SS's Avatar
    Wherever life takes me
    02 35th LE Camaro SS
    It was me that did the calculation
    Jun 2009
    Mass
    silver/black
    00 trans am,SLP,Ws6
    I am already pushing past 500HP, I haven't hit the 1/4 track yet but i will here and there.(after a new rear)
    it is more of a bad ass DD.
  1. November 2011 Chevy High Performance Parts - Parts Rack
    Last Post: 09-15-2011, 09:10 AM
  2. Replies: 0
    Last Post: 02-13-2007, 10:10 PM
  3. PARTS PARTS PARTS...tires, LCAs, relocation brackets, etc.
    By BackinBlack02SS in forum Parts For Sale / Trade
    Last Post: 02-28-2006, 03:41 PM
  4. PARTS PARTS PARTS...tires, wheels, sway bar, G-Tech, etc.
    Last Post: 01-29-2006, 01:36 PM
  5. FOR SALE: T-top conversion Hugger ORANGE parts, ebony interor parts!
    By camaros4ever in forum Parts For Sale / Trade
    Last Post: 11-21-2005, 12:17 PM
