Thread: traction control stuck off
01-22-2012, 05:23 AM #1
- Sep 2008
- Atlanta, GA,Ft.Walton Bch,FL
- Blog Entries
- 1
silver- 99 ws6
normalley when I start the engine I allways turn the TCS off unless the road is wet then leave it on.
well the other day it was raining I noticed that my traction control sys. was off went to turn it on and could'nt
I'm thinking the toggle switch has finalley burned up,
?1. if I have continuity w/ switch on and off would this indicate only the switch is bad and not something else w/ TCS?
?2.can I substitute the OEM switch w/ a regular on off toggle? not sure if I can because if I remember correctly there are more than 2 wires connected to this switch.
Thankscam-LTs-FAST78-Susp.-Rims
01-22-2012, 09:02 AM #2
- Jan 2009
- North Jersey
If I recall, you should have a reading with the meter set to Ohm. If you get power with the switch off, then it's bad. Is your ABS light lit? You could have an ABS fault resulting from a bad wheel sensor or blown fuse. As far as substituting, check how many terminals are on your factory switch.
01-22-2012, 10:47 PM #3
- Sep 2008
- Blog Entries
- 1
silver- 99 ws6
OK " If you get power with the switch off, then it's bad" this makes sense because I'm mearsuring on back terminals w/ power in off = burned contacts.
I'll post up the # of wires on back of switch.
ABS anti lock brakes light isn't no the dash
Thanks
01-26-2012, 05:13 AM #4
- Sep 2008
- Blog Entries
- 1
silver- 99 ws6
the TCS started working normalley again I say again because it has stuck itself off in the past guess it's one of those mysteries of the unknown.
now the rear window defroster is malfunctioning it comes on w/ light on the control panel however it only stays on for about 30 seconds then it turns off and it is'nt defrosting the rear dew on the window, normalley the frost or dew is gone w/in 20 seconds.
I'll try to clean the electrical contacts at the window.
any thoughts?
Thanks
01-26-2012, 09:43 AM #5
- Jan 2012
- Alabama
Bright Rally Red- 2001 Chevy Camaro Z28
My ASR was stuck off for several days but has now started working again. I noticed around the same time that my rear-window defroster wasn't working. The light on the dash came on when I pushed the button but it didn't appear to be working, so after several minutes I turned it off.
2001 Chevy Camaro Z28 A4
SLP cold air intake/lid, SLP smooth bellow, Pacesetter LT's, ORY, Magnaflow exhaust, BMR STB, adjustable Panhard rod, SFC's, LCA's, 1LE sway bars, cross-drilled rotors
01-26-2012, 12:39 PM #6
do they share the same relay?
(also I have no TCS so on this subject not much help)
01-26-2012, 02:35 PM #7
- Jan 2012
- Alabama
Not sure, but it might be worth checking. My ASR has since started working normally, though. I need to see if the rear defroster works now.
01-26-2012, 04:41 PM #8
- Jan 2009
- North Jersey
I would check fuses and relays just to be safe.
Help: traction control
By driller in forum General HelpReplies: 11Last Post: 10-23-2011, 04:08 AM -
cruise control with traction control
By basballny2 in forum General HelpReplies: 12Last Post: 06-16-2010, 11:57 PM -
Possible to add traction control???
By patriot1136 in forum Firebird / WS6Replies: 17Last Post: 10-04-2007, 06:23 PM -
traction control on or off????
By clg82 in forum Firebird / WS6Replies: 9Last Post: 04-29-2007, 10:49 AM -
Traction Control
By daryl.l in forum Firebird / WS6Replies: 4Last Post: 03-05-2006, 01:05 PM
