Thread: traction control
10-20-2011, 08:15 AM #1Junior Member
- Nov 2010
- texas
navy blue- 2000 trans am ws6 ls1 slp
traction control
i have a 2000 ws6 t.a. with traction control, i purchased a 2002 nontraction control rearend, what are, if any problem's with leaving the traction wire's off on this change,thank's for the info.
10-20-2011, 08:24 AM #211 years of bangin gears
- Jan 2009
- North Jersey
You will have an "ABS INOP/TRAC INOP" light on your dash and your ABS will not work.
10-20-2011, 09:05 AM #3Member
- Mar 2007
- NC
NBM- 1998Z28
I would think you could take the parts off your old rearend and put then on the one you bought. Your old one has the sensor behind the brake assembly and the one you bought has the sensor on top the rear gear housing?
10-20-2011, 10:07 AM #4
There is a reluctor ring on the ring gear inside the rearend as well, all that would have to be swapped.
10-20-2011, 02:59 PM #5
You could swap your brake backing plates and axles over to the new rear (I think... someone check me on this) and simply leave the sensor on top of the differential housing unplugged. Your original axles will have reluctor rings pressed onto the ends between the bearing and flange.
10-21-2011, 09:39 AM #6
Well if you don't care for having ABS or traction control there should'nt be any problem @ all..
You can always pull the cluster and remove the bulbs for the ABS and TC warning lights as I don't think there's any other way to get them to turn off..
Well that is unless you add the parts required to make those options work with your new rear..
Oh, and welcome to LS1.com..
10-21-2011, 10:24 AM #7Member
- Mar 2007
- NC
NBM- 1998Z28
10-21-2011, 11:29 AM #8
Hmmm, I was under the impression that he bought a NON traction control rearend and needed to make it work on his traction control car.
In which case the rearend wouldn't have a reluctor ring on the 3rd member. Which is why I mentioned needing to swap it to make it all functional again.
Anyone want to clerify what the original posters actual intentions are?
10-21-2011, 12:56 PM #9Junior Member
- Nov 2010
- texas
no more t.c.on t.a.
thank's for all the info ,beside's the light's sound's like i shouldn't have any computer sensor problem's,all my other rod's 69-442,78-t.a. 80-t.a. 79-z28,69-gto,didn't have traction control or abs,so this is kinda silly when you want power&burnout,i just wasn't sure how it would affect the computer stuff,i like this 2000 t.a. but didn't realize how much crap i will have to learn, thank's this is a very helpful group of ls1nee's
10-21-2011, 01:59 PM #1011 years of bangin gears
- Jan 2009
- North Jersey
That's what we're here for.
10-22-2011, 07:12 AM #11Senior Member
- Apr 2008
- Madison, WI
His car has TC (4 channel) and he bought a ABS only rearend (3 channel). To make the TC/ABS work, he can leave the center reluctor in and swap the axles w/ the reluctors pressed on, from the old rearend. But it sounds like he doesn't want ABS or TC so....he doesn't have to do anything, I guess
10-23-2011, 04:08 AM #12
cruise control with traction control
By basballny2 in forum General HelpReplies: 12Last Post: 06-16-2010, 11:57 PM -
traction control
By racer426 in forum GTOReplies: 8Last Post: 12-16-2008, 07:04 PM -
traction control
By jordanvb in forum General HelpReplies: 15Last Post: 12-12-2008, 01:48 PM -
abs and traction control
By davidz28guy in forum CorvetteReplies: 7Last Post: 08-12-2006, 08:28 PM -
Traction Control
By daryl.l in forum Firebird / WS6Replies: 4Last Post: 03-05-2006, 01:05 PM
