Thread: traction control
12-08-2008, 08:56 PM #1
traction control
there is a plug under the cruise control box on a 04 a4 goat unplug it because it cuts the trac control off. trac is controlled by the cruise mech.cruise will still work and pcm will see no diff.. burn out city!
12-09-2008, 04:22 AM #2
12-09-2008, 04:30 AM #3Grand Imperial Wizard
- Retired Outlaw Sum Bitch
I just use Chimp Daddy....TC off by default and I can turn it on if needed...
12-11-2008, 05:28 PM #4I went to Playboy Mansion
- Sep 2005
- Bakersfield/Long Beach Ca
YJ- 04 GTO M6
You can always blow out a hub bearing causing the ABS to turn off and that automatically turns the TC off(personal experience)
12-11-2008, 10:14 PM #5
12-12-2008, 03:20 PM #6
FZguy 28, are you saying that if you disconnect the wire it can take out the hub bearing because they are interactive with each other? Sorry about your experience you had. Thanks in advance and MC, Jack
12-13-2008, 07:35 AM #7
12-13-2008, 04:14 PM #8
Thanks' brother!!
12-16-2008, 07:04 PM #9
I think if you pull that plug, it also turns off the CAGS thing. Which also turns off the reverse lockout. Could be wrong though. For some reason, it's coming to mind that all that is controlled by the same thing.
cruise control with traction control
By basballny2 in forum General HelpReplies: 12Last Post: 06-16-2010, 11:57 PM -
traction control
By jordanvb in forum General HelpReplies: 15Last Post: 12-12-2008, 01:48 PM -
Traction Control
By WS6ICK2K in forum Manual TransmissionReplies: 7Last Post: 01-09-2008, 05:53 PM -
abs and traction control
By davidz28guy in forum CorvetteReplies: 7Last Post: 08-12-2006, 08:28 PM -
Traction Control
By daryl.l in forum Firebird / WS6Replies: 4Last Post: 03-05-2006, 01:05 PM
