    Jan 2012
    Ft Meade
    RED
    1998 Camaro
    Thumbs up Intake Inquiry??
    I am getting started on a build its going to be a 6.0 conversion on a V6 98 camaro, Will the stock intake work for now or should I run a LS6 intake. I am not sure but I thought I read that the heads on the 6.0 will match the LS6 intake manifold. Any info will help.
    Junior Member dbot362's Avatar
    Dec 2011
    mesa
    1974 Nova
    6.0
    Is the 6.0 out of a truck? If it is you are definitely better off with the LS6 intake. Better flow and better top end performance. Clearance could very well be an issue as well with the taller truck intake.
    Dec 2011
    mesa
    1974 Nova
    6.0
    Is your 6.0 out of a truck? If so, the top end performace and overall flow with the LS6 is far better than the truck intake. You may also have hood clearance issues with the taller truck intake. Yes to the LS6.
    Dec 2011
    mesa
    1974 Nova
    heads
    And yes LS6 intake will work with any "cathedral port" head setup.
  1. GM vehicle inquiry system
    By konigandy6 in forum Camaro / SS
    Last Post: 02-24-2015, 09:12 PM
  2. Rear End Inquiry??
    By cade75 in forum Drivetrain
    Last Post: 01-26-2012, 06:16 PM
  3. Question: TTop Inquiry
    By fbodyNATION in forum Camaro / SS
    Last Post: 02-02-2011, 04:47 AM
  4. Plug Change Inquiry
    By ss~zoso~ss in forum General Help
    Last Post: 08-09-2006, 02:39 PM
