Thread: Rear End Inquiry??
01-26-2012, 04:34 PM #1Junior Member
- Jan 2012
- Ft Meade
RED- 1998 Camaro
Rear End Inquiry??
I am getting started on a 98 V6 Camaro Conversion to and LS powered ride. My question is will the stock rear end hold up until I buy a V8 unit or can I gut it and buy the gears and axels to save some cash.
01-26-2012, 04:50 PM #2None Shall Pass
- Jan 2010
- East of Cleveland, Ohio
Black- 99 WS.6 - Modified
The rear end is the same, no matter if the car came with a v6 or v8, save gear ratios. It is a 7.5"/7.65" 10 bolt. Sadly, they are quite weak. The v6's have been known to break them. It's not worth trying to upgrade them either, as they just simply cannot handle the power. Most upgrade to a 12 bolt if a4, or 9" if m6. You can probably retain the stocker until after the swap, being gentle with it.
01-26-2012, 05:26 PM #3Junior Member
- Jan 2012
- Ft Meade
RED- 1998 Camaro
01-26-2012, 06:16 PM #4None Shall Pass
- Jan 2010
Glad to help. That's what the site is for.
GM vehicle inquiry system
By konigandy6 in forum Camaro / SSReplies: 1346Last Post: 02-24-2015, 09:12 PM -
Intake Inquiry??
By cade75 in forum External EngineReplies: 3Last Post: 01-21-2012, 12:57 AM -
Question: TTop Inquiry
By fbodyNATION in forum Camaro / SSReplies: 1Last Post: 02-02-2011, 04:47 AM
