Thread: serpentine belt
01-17-2012, 04:01 PM #1Member
- Apr 2007
- tx
black- 02 trans am ws6
serpentine belt
ok i have had it my serpentine belt wont shut the fuck up i have all ready put a new one on and still crying like a bitch also put a new water pump, power steering pump, and alt. i was woundering may my belt tensioner be to weak to keep tighter need help its no fun any more
mad:
01-17-2012, 04:05 PM #2None Shall Pass
- Jan 2010
- East of Cleveland, Ohio
Black- 99 WS.6 - Modified
It's possible the tensioner or idler may be bad. You also have a belt for the AC. You may want to check that as well, and the pulleys.
01-17-2012, 05:42 PM #3
Agreed. Pull the ac belt and see if it disappears. I hope you didn't replace all that trying to get rid of the noise and it hasn't helped. A solid tensioner fixed my screaming belt
LS6 Intake, LS6 VCT, E^2 Catch Can, Hooker LTs and ORY, Magnaflow Cat-Back, 3" QTP electric cutout, UMI adj LCA, PHB, 3 pt SFCs, STB, MGW Shifter, SLP lid and bellow, Free-Mods, Tuned by BlueCat
01-19-2012, 05:56 PM #4
A can of spray belt dressing will give you temporary relief - however, as posted, it is likely that you have a tensioner or idler pulley on the way out, or your tensioner spring has weakened over time. Also, some belts just squeal no matter what you do. Belt dressing can help you diagnosis and pinpoint the issue as you see how the belts respond to it. FWIW, I would try a Goodyear Gatorback for a replacement belt if given a choice.
Help: Serpentine belt
By derekbuckner1 in forum General HelpReplies: 21Last Post: 08-15-2012, 06:44 AM -
Serpentine belt
By 00hawk109 in forum External EngineReplies: 6Last Post: 06-20-2009, 03:14 PM -
Help: Serpentine Belt!
By slowss416 in forum General HelpReplies: 10Last Post: 04-04-2008, 10:55 AM -
Serpentine belt
By derbs in forum LT1Replies: 3Last Post: 03-28-2007, 04:54 PM -
serpentine belt help!!
By 2kss in forum Camaro / SSReplies: 7Last Post: 01-06-2007, 09:45 AM
