Results 1 to 20 of 22
Thread: Serpentine belt
07-31-2011, 10:21 PM #1
Serpentine belt
If I take the car up towards 6k rpm my serpentine belt likes to slip off the tensioner. Not completely throwing the belt but it kicks over about half an inch off the pulleys.
Any advice?
Adjustable tensioner? I was told some other ls tensioners had taller walls on the pulley, not sure if that's true or not.
LS6 Intake, LS6 VCT, E^2 Catch Can, Hooker LTs and ORY, Magnaflow Cat-Back, 3" QTP electric cutout, UMI adj LCA, PHB, 3 pt SFCs, STB, MGW Shifter, SLP lid and bellow, Free-Mods, Tuned by BlueCat
08-01-2011, 07:19 AM #2
Is the tensioner bad?
08-01-2011, 08:20 AM #3
Take a look at this: http://www.ls1.com/forums/showthread...belt-tensioner
I would check all your pulleys with the belt off to ensure that nothing is loose and that they all run true. Also, take a look at your balancer to ensure that nothing is askew.
08-01-2011, 08:24 AM #4None Shall Pass
- Jan 2010
- East of Cleveland, Ohio
Black- 99 WS.6 - Modified
^This. You may also want to check the spring tension on the tensioner. They will wear and not hold as they should too.
08-01-2011, 08:42 AM #5
Thanks guy. How do I check the tensioner to see if it is bad? And thanks Jeff. I'll try to look into a katech tensioner. It doesnt happen often now I was just wanting to find a fix before I (hopefully) swap my cam this winter and crank a little higher rpms.
08-01-2011, 10:15 AM #6
With out the motor running, you can put a wrench on the tensioner and see if it is hard to move. Mine was completely shot so it was easy to tell. But I've had one in the past that I thought was good, but a mechanic told me it was bad. They should be pretty tuff to move. Or see if you have any slack in your belt. I think +/- a half inch.
08-01-2011, 01:18 PM #7
08-01-2011, 02:34 PM #8
08-01-2011, 03:03 PM #9
Sometimes when the belt tensioner is getting bad, it will actually kick out of alignment. I would guess yours is just starting to get bad, thus why it's only doing it at higher rpms. It will get worse and eventually keep kicking the belt off. New belt and tensioner should fix it.
Dan
08-01-2011, 03:06 PM #10Senior Member
- Jan 2010
- texas
silver- 2000 formula
http://www.ls1.com/forums/showthread...nstall-in-pics
holy read my mind batman !!!!
08-01-2011, 03:41 PM #1111 years of bangin gears
- Jan 2009
- North Jersey
I agree with all of the above. Wobbly crank pulley, worn/crooked tensioner will cause the belt to slip/fall off. Keep us posted.
08-01-2011, 09:45 PM #12
I'll look into all the above this weekend when I get the time to do so. Thanks again for all the advice. I will post up anything I come up with
08-01-2011, 11:41 PM #13Electrical Engineer
- Jul 2009
- North of the Motorcity
Go with a gatoback belt!
01-11-2012, 07:49 PM #14
hate to bring this thread back to life, but the belt trouble didnt happen for a long time. When i started the car earlier this week, the belt whined like crazy. it was on track as it should be. i have a katech tensioner and a gatorback belt in the mail and will let you guys know if it fixes the problem
01-11-2012, 09:07 PM #15Electrical Engineer
- Jul 2009
It def. should.
01-12-2012, 06:22 AM #16
01-12-2012, 09:49 AM #17Electrical Engineer
- Jul 2009
Are you replacing both belts?
01-13-2012, 03:33 AM #18
Yeah. The belt I ordered originally was the ac belt. Summit racing had it listed as the serp belt and was the only one they had. Now I have the ac belt and have to find the serpentine belt elsewhwre
01-16-2012, 10:55 AM #19
if you can i would not use a gator back belt I have had maney of them come back into the shop after being installed for squeeling and chirping. mostly on fixed tensioner cars though. i prefer gates belts jmho
00' SS 6m TTops 4.10's pacesetter lt's SLP lid borla cat back and tune.
No times yet
01-17-2012, 04:03 AM #20
This one has already been ordered. I saw many mixed reviews on the belt before placing my order and it seemed like many people loved them. If I have issues with it I will give gates a try. I've never used a cross hatched belt like the gator back before, but I thought I would give it a try
Question: serpentine belt
By txoutlaw69 in forum Firebird / WS6Replies: 3Last Post: 01-19-2012, 05:56 PM -
Serpentine belt
By 00hawk109 in forum External EngineReplies: 6Last Post: 06-20-2009, 03:14 PM -
Help: Serpentine Belt!
By slowss416 in forum General HelpReplies: 10Last Post: 04-04-2008, 10:55 AM -
Serpentine belt
By derbs in forum LT1Replies: 3Last Post: 03-28-2007, 04:54 PM -
serpentine belt help!!
By 2kss in forum Camaro / SSReplies: 7Last Post: 01-06-2007, 09:45 AM
