Results 1 to 20 of 25
Thread: Ngk tr55
    new jersey
    Ngk tr55
    Of course most people seem to recommend NGK TR55. Searching for them online this morning.Autozone, Advanced Auto, I dont see an exact match. Then I just searched NGk's site. It let me pick my car - 02 Trans Am - and it listed the following - Any easy way to explain how to get the plug everyone is talking about.
    Thanks
    Kelly
    James Bond Spikito's Avatar
    2001 3.8 Black - sold
    2000 SS Black M6
    most of our sponsors stock them...just got mine from kyspeed
    Veteran 35th-ANV-SS's Avatar
    Wherever life takes me
    02 35th LE Camaro SS
    Here is the link to purchase them through KYSPEED, which is a site sponsor: NGK : KY SPEED, Performance Parts for Corvette, Camaro, Firebird, GTO, G8, TBSS, Mustang, Challenger, Charger
    2000 SS Black M6
    thats who i bought them through
    Senior Member Lunatikgixxer's Avatar
    Mar 2010
    St Pete, FL
    Bat mobile black
    2000 Trans am WS6 M6
    Definitely check the sponsor sites or other sites before autozone. KY!
    Come to think of it, I believe I ordered mine from KY Speed when I bought my headers.
    new jersey
    Thanks. Ordered from ky yesterday along with the wires. Now even though i have read all of the tips on changing plugs i might just let a trusted mechanic do it. Thanks all.
    It's not that bad -- pop the plastic pins up that retain the cowl seal, remove the coil packs to give yourself some space and have at it. Get No. 8 from below and be sure to double click the wires onto the coil packs when you reinstall them.
    Jun 2011
    Branchville, NJ
    Silver & Blue
    02 Camaro SS, 04 GTO
    Be careful with #8. you may want to use a wrench on a socker from above or an extension and universal from below. remember to use dielectric grease for a better connection and waterproofing.
    Junior Member Blue2KTA's Avatar
    Lake Worth, Florida
    Blue
    2000 Trans Am
    On #8, when you say below do you mean directly under the car or through the wheel well ? I will be changing mine soon (1st time)
    Mar 2010
    St Pete, FL
    Bat mobile black
    You can change it from the top if you have long tubes. Just point the ratchet towards the rear of the car when loosening and tightening. Its really not that bad once you do it 2-3 times. Make sure you take the coil pack off though it will make it 100% easier to do.
    I found No. 8 to be easiest from underneath the car - there is no way to get at it through the wheel well that I could see. A very short 1-1/2" extension for your 3/8" drive ratchet also seems to come in handy for a lot of the plugs.
    Lake Worth, Florida
    Blue
    2000 Trans Am
    Should the car be lifted from sides so it hangs or use a set of ramps ?
    Does not really matter -- just so it is done in a safe manner. You won't want to have it too high in the air as you need to be able to reach up to the plug.
    2000 SS Black M6
    i understand the reasoning behind a colder plug....but can someone explain to me why someone would want a hotter plug?
    I forgot what gap does TR55's (no N2O) need to be set at?
    2000 SS Black M6
    everywhere I've read says .040, but ive also heard of guys opening it up a little,
    now why do I keep thinking .050?
    2000 SS Black M6
    well thats what im saying, NGK suggests .040, but a lot of guys widen them
    Mar 2010
    St Pete, FL
    Bat mobile black
    between .40-.50. I think they come pre gapped at .40
  1. TR5 or TR55
    By 99yellowz28 in forum External Engine
    Last Post: 09-04-2009, 07:01 PM
  2. NGK TR55's??
    By rbob93 in forum Almost Anything Goes
    Last Post: 08-10-2009, 12:40 PM
  3. TR55 or TR6
    By Mr. Luos in forum External Engine
    Last Post: 04-22-2007, 07:19 PM
  4. spark plugs, tr55 iridium or plane tr55 plugs?
    By got-a-ls1 in forum General Help
    Last Post: 02-09-2006, 06:06 PM
  5. NGK Tr55's
    By articz28 in forum General Help
    Last Post: 09-28-2005, 07:37 AM
