Results 1 to 20 of 29
    Sep 2011
    Orlando
    Trans am
    $1,500 to spent on my car
    i have a 01 Trans Am A4, i have 1500 to spent on my car, looks or bolt ons. i have Headers, SLP Intake, SLP Tuner, Full 3" Exhaust.
    I was thinking of getting a Intake Mainfold to replace the stock 75mm Ls6 intake mainfold with something like 102mm or 96mm.
    May 2010
    Wilkes-Barre, PA
    Black/Black
    98 WS6/04 Sierra Dmax
    Stall converter and some rear suspension upgrades would be at the top of my list if I were you.
    Sep 2011
    Orlando
    Trans am
    best i ran is 8.51 @ 86mph with stock suspension. will a stall and rear suspension get me to 7's in a 1/8
    May 2010
    Wilkes-Barre, PA
    Black/Black
    What were your 60ft times? most likely you will be low 8's with just a stall.
    Jul 2009
    North of the Motorcity
    Custom Swirly Black
    2001 WS6 M6
    Stall, really good tune and tires. Suspension if anything is left over. That's if your et is your immediate goal.
    Veteran 35th-ANV-SS's Avatar
    Wherever life takes me
    02 35th LE Camaro SS
    You really won't see that much of a gain over the LS6 intake unless you are coupling that new intake with a cam/heads.
    I'd go for a stall and tranny cooler. If you don't have them already, sub-frame connectors also.
    Sep 2011
    Orlando
    Trans am
    8.51 with a 2.10 60ft with street tires 245-50-16.
    Add a stall, get that 60' down into a 1.7 and you'll be in the 7's easily.
    May 2010
    Wilkes-Barre, PA
    Black/Black
    Yup without a doubt. Make sure when you do the stall you get the biggest tranny cooler you can fit. And its a good idea to put a trans temp gauge in so you can keep an eye on things.
    Dec 2010
    Upstate, SC
    1999 camaro
    Stall and suspension parts
    1995 Z28 A4: 353 LT1 Heads/Cam/Stall, awaiting !opti or !LT1
    1999 SS M6: Pacesetter Longtubes, SLP 2otl catback, E-cutout, 218/218 .563 .563 112lsa cam, Ls6 injectors, Ls6 intake, 85mm maf, Whisper lid, Pro 5.0, 4.10 gears, UMI sfc, Founders LCA & PHB, Tuned by v8muscle.net
    stall and a real tune
    Sep 2011
    Orlando
    Trans am
    will 228R Cam, Tune, GoodYear Drag Tires and upgrade suspension or stall will be find. i want to get 400rwhp with a cam "currently guessing im at 355rwhp and tires to get my 60ft from 2.1 to 1.7
    Broken Arrow, Ok
    2000 Z28
    Quote Originally Posted by FMR_TransAm View Post
    You don't need 400rwhp to get a 1.7 60'. The 60' time with a A4 is all based off the converter setup and gears IMO. A good converter or better gears will drop that 60' period. A 3500 converter would be a good start with a stock cam. But you could do the same with 3.73's gears. The stock 10 bolt while good tends to not last long. So I would save the money for a 12 bolt or 9" IMO. With just a 3500 converter and headers (minus cats and exhaust dropped at the axle) you should see 1.7 60's.....
    Member derekbuckner1's Avatar
    Oct 2009
    West Virginia
    LPM
    2000 Z28
    It will take larger than a 228 cam to get you to 400rwhp without heads. IMHO
    LS6 Intake, LS6 VCT, E^2 Catch Can, Hooker LTs and ORY, Magnaflow Cat-Back, 3" QTP electric cutout, UMI adj LCA, PHB, 3 pt SFCs, STB, MGW Shifter, SLP lid and bellow, Free-Mods, Tuned by BlueCat
    Aug 2010
    NEW ALBANY
    2002 ws6 ta convertible
    Nitrous lots and lots of nitrous!!!!
    Sent from my DROID BIONIC using Tapatalk
    TRUE DUALS
    Broken Arrow, Ok
    2000 Z28
    Quote Originally Posted by derekbuckner1 View Post
    Very true Sir.... And back to the 1.7 60'... I ran a 12.533@108.01 1.75 60' with just headers and a converter..
    Oct 2009
    West Virginia
    LPM
    2000 Z28
    Not bad man. I was going to recommend tires if he wanted a 1.7x 60'
    Sep 2011
    Orlando
    Trans am
    im on steet tire 245 i was going to get Mickey Thompson Performance Tires & Wheels. for grap. and does a stall really to that much. i dont know alot about stall's so what does it do to make you go off the line .
    Turbo PT-T88 TH400 12psi pump gas "675rwhp"
    Oct 2009
    West Virginia
    LPM
    2000 Z28
    It lets you flash your rpms much higher before the car is going to pull itself forward. It's a night and day difference in an auto car...
    Broken Arrow, Ok
    2000 Z28
    Durr I always forget that.. Tires... That was with used Nitto's......
  1. Spent 15 hours detailing the DDs
    By Sweet Chops in forum Showcar and Detailing
    Last Post: 11-07-2011, 06:01 AM
  2. wow i spent $150 on booze tonite
    By EnjoiJoe in forum Almost Anything Goes
    Last Post: 12-27-2009, 09:17 PM
  3. Spent a lot of money! On Goodies!
    By Blue_01_Z28 in forum Camaro / SS
    Last Post: 05-27-2009, 02:51 AM
  4. What i've spent
    By Dr.Crash in forum Camaro / SS
    Last Post: 03-14-2009, 12:00 PM
  5. *Pic* Spent 4 hours in the ER with my little boy tonight.
    Last Post: 02-22-2006, 06:46 AM
