Results 1 to 11 of 11
    Member izzhemp's Avatar
    Osawatomie KS
    white/Black
    1999 Pontiac Firebird
    changed fuel pump still wont start
    Put newer used fuel pump in an car still won't start any ideas
    Pittsburgh
    2008 Hummer H3
    Can you hear it (fuel pump) running, and test rail pressure just to be sure?
    Pittsburgh
    2008 Hummer H3
    Does the engine just spin or does it try to fire?
    Junior Member BIGGDADDYWIGGS's Avatar
    Martinez Ga
    Blog Entries
    2
    Triple Black
    2002 Ram Air Trans Am
    Same thing with my 96 Trans am
    Had the same thing happen to me, changed out everything that I thought was wrong. Ended up being the Crank Positon Sensor. It stated by the car shutting off while driving then I'd have to let it sit for awhile to start, then it would only go about a mile and shut off again.
    Veteran 35th-ANV-SS's Avatar
    Wherever life takes me
    02 35th LE Camaro SS
    First thing I would do is check the fuel pressure at the fuel rail as Steven mentioned.
    And not to state the ever so obvious, but also make sure there is fuel in the car
    East of Cleveland, Ohio
    99 WS.6 - Modified
    ^This. You should see around 58 psi at the rail.
    Pittsburgh
    2008 Hummer H3
    I think he's a V6 bud.
    The 3800-II in f-body with 22 lb. injectors runs @ ~ 48-55 psi..
    With a 3-10 lb loss @ idle.
    99 WS.6 - Modified
    Good catch. Didn't notice that, and my mind is usually set to the LS1 standards.
    I knew it was a tad lower in the V6's being I've checked mine before when I had it, but couldn't recall the exact pressure or I would have posted it. I knew Smitty would have my back there
    Osawatomie KS
    white/Black
    Got it running, i checked everything mentioned all was fine let it sit few more hours then it started up an stayed running, already noticing increase in fuel mileage glad the old bird didn't bite the dust thanks everybody
    99 WS.6 - Modified
    Have some air in the fuel line that purged out?
    No matter, glad it's back up and running for you.
  1. Still wont start after fuel pump install
    By OneFastZ in forum General Help
    Last Post: 08-10-2015, 07:31 AM
  2. Ls1 won't start/ just replaced fuel pump
    By Bigjames25 in forum General Help
    Last Post: 10-09-2013, 09:02 PM
  3. Wont Start!!! No spark, but have fuel
    By Lucky 13 in forum General Help
    Last Post: 07-07-2009, 12:10 PM
  4. Fuel pump wont come out...need help[ fast!!!
    By ttocs in forum General Help
    Last Post: 04-28-2006, 05:53 PM
  5. Replies: 26
    Last Post: 01-17-2006, 09:51 PM
