Results 1 to 2 of 2
11-29-2011, 09:29 PM #1Member
- Sep 2011
- Orlando
Black- Trans am
Need alot of Help with Turbo Setup
01 trans am A4
On December Im ordering a Turbo kit of ebay 98-02 CAMARO FIREBIRD TRANS AM LS1 FULL RACE TURBO KIT | eBay
comes with
1. TO4B T4 Turbocharger with Air Filter and Air Bearther Filter !!
2. 98-02 Camaro LS1 Stainless Steel Turbo Manifold
3. 98-02 Chevy Camaro LS1 3" High Flow Turbo Exhaust Downpipe
4. JDM SPORT 38mm External Turbo Wastegate & Turbo Boost Controller
5. Light Weight Aluminum Mandrel Bent Intercooler Piping
6. JDM SPORT Turbo (Inlet/Outlet) Oil Feed Line with Oil Retrun Line Kit !!
7. JDM SPORT 2" Oil Temperature Gauge & Vaccum Gauge
8. JDM Sequential Style Blow Off Valve
9. 255LPH High Flow In Tank Fuel Pump
10. Oil Catch Tank (PRO-Version)
then buy BMR K - Member " fit the extra exhuast piping
42Ib Injectors
and is their anything im missing for my car to run. and is JDM a good brand?
going to run 6psi on "DD" and 8psi on Drag
12-22-2011, 02:26 PM #2Junior Member
- Dec 2011
- longwood
Thats the kit i bought and i hate to say it but better off buying the godspeed hotside and go from there... The jdm bov straight up doesnt work and youll pop pipes...
The jdm wastegate leaks soo much internally its useless
The to4b is wayy too small my ls1 wouldnt rev past 4k
The cold side is good and hot side is ok... Best way to go is get a bmr turbo kmember and do a custom downpipe and save all the big headaches... You gotta relocate fans to front too... Dump wastegate... Get solid umi mounts(work with bmr kmember over other solids)
Use header wrap and turbo blanket... Relocate alt to top... Custom or bend power steering pressure hose and redo return with an external cooler...
Thennnn your factory ls1 valve springs will valve float under boost(mine under 5k)...
But after all the b.s. i now have a fun car... My t67 builds boost pretty fast too...
Need Help with a Turbo Setup on a 01 trans am A4
By FMR_TransAm in forum Forced InductionReplies: 4Last Post: 11-22-2011, 07:20 PM -
wtb superchager or turbo setup
By full_360 in forum Parts Wanted / TradeReplies: 4Last Post: 05-06-2009, 11:10 AM -
Need help selecting a Turbo setup?
By tyls6ta in forum Forced InductionReplies: 12Last Post: 10-15-2007, 04:09 PM -
Twin Turbo Setup, t70's
By xssive in forum Parts For Sale / TradeReplies: 0Last Post: 08-20-2007, 03:58 PM -
Looking for small turbo setup
By TransAmcoupe98 in forum Forced InductionReplies: 6Last Post: 07-17-2007, 04:05 AM
