11-21-2011, 11:39 PM #1Member
- Sep 2011
- Orlando
Black- Trans am
Need Help with a Turbo Setup on a 01 trans am A4
im going to get a turbo kit HKS brand from ebay 98-02 CAMARO FIREBIRD TRANS AM LS1 FULL RACE TURBO KIT | eBay. | But replace the Turbo, BOV, & Wasteage with a Turbonetics Turbo, BOV and Wastegate and allow 10psi of boost. with a BMR K Member and 42Ib injectors. is this everything or im i missing some thing.
11-22-2011, 07:29 AM #2
At a minimum you're also going to need gauges (boost/vac and A/F) and a fuel pump.
Have you calculated that 42-lb injectors are big enough for 10psi? I'm running 8psi and have 62-lb injectors.
I'm not turbo'd, but running a Procharger. My tuner (FROST on here) HIGHLY recommended a methanol injection kit with FI so I went with the AlkyControl system. They also recommended hardened push rods and new valve springs.
Here is my thread which details everything I bought if you want to reference it: http://www.ls1.com/forums/f11/my-pro...-kinda-153052/
11-22-2011, 08:14 AM #3Member
- Sep 2011
- Orlando
Black- Trans am
the kit includes everything but the k member and injectors. ls1 stock are 28ib injectors, but i dont know i know their turbo trans am's using 42ib injectors. im alsoo going to safly run 7-9psi on DD and 10 - 12psi drag racing.
11-22-2011, 06:10 PM #4
Well I know for a stock LS1, 8psi is about the maximum everyone I've ever talked to recommends.
If you run more than that, I would think about forged pistons and connecting rods. A lot of people crack piston #8 who run in the 12psi range without any engine upgrades.
11-22-2011, 07:20 PM #5Member
- Sep 2011
- Orlando
Black- Trans am
so 7 -8 psi of boost in good? ok then and is there anything else i need that was included on ebay
Need alot of Help with Turbo Setup
By FMR_TransAm in forum Forced InductionReplies: 1Last Post: 12-22-2011, 02:26 PM -
wtb superchager or turbo setup
By full_360 in forum Parts Wanted / TradeReplies: 4Last Post: 05-06-2009, 11:10 AM -
1999 Trans Am, 6speed 408ci w/ turbo setup
By TINKRD in forum Vehicles For Sale / TradeReplies: 6Last Post: 04-21-2009, 12:37 PM -
Need help selecting a Turbo setup?
By tyls6ta in forum Forced InductionReplies: 12Last Post: 10-15-2007, 04:09 PM -
Looking for small turbo setup
By TransAmcoupe98 in forum Forced InductionReplies: 6Last Post: 07-17-2007, 04:05 AM
