    Oct 2011
    Chippewa Falls, Wisconsin, Uni
    Navy BLue
    1999 Chevrolet Camaro Z28
    Coolant not being drawn back into the radiator. HELP
    I'm having a problem with my car not drawing the coolant back into the radiator after being pushed into the overflow bottle. Just wondering if anyone knew what was causing this. I took the overflow bottle and coolant line that runs back to the radiator off and cleaned them out. It will warm up just fine, get to 210 degrees and then sit there, once it cools down the low coolant light comes on and I have to take the cap off and pump it back into the radiator. Anyone know what could be causing this??
    Jun 2011
    Branchville, NJ
    Silver & Blue
    02 Camaro SS, 04 GTO
    Your waterpump may be on it's way out. They sometimes will lose fins on the inside of the pump. It is a good idea to change your coolant every three years with the factory Dexcool, what have you been using and how often is it changed ?
    Georgia
    red black
    98Z28
    How old is the cap? If its old try changing it first.
    Oct 2011
    Navy BLue
    cap is original and i just flushed out the radiator this summer, i pulled the water pump off to replace the gaskets a few weeks ago and the water pump looked fine so i dont think it's going out.
    Junior Member Canadian LS1's Avatar
    Jun 2011
    Calgary Alberta Canada
    Bright Red
    1998 Camaro Z28
    i second the motion....try a rad cap
    North Jersey
    Phantom Black Metallic
    2004 GTO M6
    If any of your hoses are collapsed while the engine isn't running, then your radiator cap is faulty.
  1. Question: Coolant in the radiator
    By Conflict in forum General Help
    Last Post: 04-03-2010, 02:44 PM
  2. Question: Changing coolant in radiator
    By Blue2KTA in forum General Help
    Last Post: 06-08-2009, 04:34 AM
  3. Help: Coolant leaking from back of engine somewhere?
    By Mayron in forum General Help
    Last Post: 09-18-2008, 10:18 AM
  4. Problem!! Coolant Boils In Radiator!! HELP!!!
    By L3THAL_Z28 in forum General Help
    Last Post: 08-31-2008, 09:48 PM
  5. Replies: 23
    Last Post: 06-19-2007, 07:28 AM
