Thread: Coolant in the radiator
04-01-2010, 12:01 AM #1Member
- Apr 2009
- Palm Desert, CA
White- 97 3.8L Firebird 5 Speed
how much coolant should be in the radiator after the car has been parked a day or so? I couldn't see any coolant in the radiator but the tank was full.My car never overheats but I had the water pump replaced a few months ago and I'm not sure if the system was bled. would "burping" the radiator be a good idea?
04-01-2010, 12:40 AM #2
Sounds like it already burped. Cap it off & check the reservoir too. As it gets hot, it overflows to the reservoir & sucks it back in when it cools. So, check the radiator cap rubber gasket too.
04-01-2010, 03:34 AM #3Senior Member
- Apr 2008
- Madison, WI
should be full. you might have a bad rad cap or the system just isn't full
04-03-2010, 12:56 AM #4Member
- Apr 2009
- Palm Desert, CA
while checking it again and adding coolant I see that it is only about 6 ounces from being full. Should I be worrying?
04-03-2010, 01:17 AM #5
I doubt it. Just keep an eye on it for a while.
04-03-2010, 02:44 PM #6Member
- Apr 2009
- Palm Desert, CA
alright because the temp gauge is never reading hot( its even a "real" gauge) and the coolant level isn't dropping
Coolant not being drawn back into the radiator. HELP
By bobh13908 in forum General HelpReplies: 5Last Post: 10-26-2011, 08:20 AM -
Question: Changing coolant in radiator
By Blue2KTA in forum General HelpReplies: 9Last Post: 06-08-2009, 04:34 AM -
Problem!! Coolant Boils In Radiator!! HELP!!!
By L3THAL_Z28 in forum General HelpReplies: 32Last Post: 08-31-2008, 09:48 PM -
Loosing Radiator coolant and milky colored coolant... what to do?
By JehalinTA in forum General HelpReplies: 23Last Post: 06-19-2007, 07:28 AM -
Project Shark Attack C3 Corvette Radiator Install - Radiator Fallout
By Ed Blown Vert in forum CorvetteReplies: 0Last Post: 04-03-2007, 09:20 AM
