Thread: power steering
    Junior Member 99maroz28's Avatar
    May 2010
    Fairfield IL
    1999 Z28
    power steering
    how do you remove just the power steering reservoir from the pump on a 1999 z28 without taking it completely off the engine?
    You can't
    Here is a thread that can help you.
    http://www.ls1.com/forums/f6/so-you-...g-leak-151991/
    Senior Member Lunatikgixxer's Avatar
    Mar 2010
    St Pete, FL
    Bat mobile black
    2000 Trans am WS6 M6
    you have to pull it off with the pump and its held on by two clamps... Do yourself a favor before you get into it and buy yourself a 13mm ratchet wrench. It will save you a TON of time. You cant reach the bolts with a socket only with a wrench unless you do like in that tutorial and take the pully off first.. Also put a towel down over your alternator so you wont get any fluids on it, if you do you will ruin it.
    Orlando, FL
    Mean Black
    Pretty much you have to remove it like the other mentioned. How old is the pump? It might be better to replace it with a new one if it has alot of miles and save you some time in the future.
  1. Help: Power steering
    By 1998ss in forum Stereo and Electronics
    Last Post: 09-17-2013, 03:02 AM
  2. I need power steering help
    By transam_00 in forum External Engine
    Last Post: 01-11-2011, 07:51 AM
  3. Question: Power Steering, Manual Rack, Power Steering Pumps-etc
    By TerribleTed in forum General Help
    Last Post: 11-18-2010, 04:37 PM
  4. power steering is no more
    By transamgirl89 in forum Camaro / SS
    Last Post: 08-20-2010, 06:27 PM
  5. power steering?
    By Spikito in forum Camaro / SS
    Last Post: 06-19-2009, 10:51 PM
