Thread: fuel pressure regulator
10-20-2011, 07:32 PM #1Member
- Nov 2010
- orlando fl
black- firebird formula 99
I was wondering how to put a aftermarket fuel regulator on, the one in the tank blew apart and the plastic part that the stock regulator snaps into is messed up and i cant get it to seal anymore so can i just put a regulator on say the firewall or somthing like that under the hood and hook it to my return line? and would i need to hook up a vac line id rather do this then buy a new unit there isnt anything wrong with what i have besides the regulator
10-21-2011, 03:55 AM #2Sold: LS1 '85 El Camino
- Dec 2005
- Laurel, Maryland
Are you running stock rails? If so, you're better off putting the aftermarket regulator in the rear of the car on the return line. Yeah, it's not the conventional way of doing it, but it should work.
Unless you're boosted, you won't need a vacuum line. That is only there to raise the fuel pressure with boost level...usually a 1:1 ratio.
10-21-2011, 03:23 PM #3Member
- Nov 2010
- orlando fl
yeah there stock rails and i patched up the stock regulator till i get the new one saturday from jegs but its the first time ive had full power in the car since i bout it 3 weeks ago it scared the shit out of me the first time i put it to the floor
10-21-2011, 06:52 PM #4Sold: LS1 '85 El Camino
- Dec 2005
- Laurel, Maryland
Are you talking about the thing on the rail, which is not the regulator, but an equalizer, or the actual regulator in the fuel tank?
10-23-2011, 08:17 PM #5Member
- Nov 2010
- orlando fl
the regulator in the tank i bought a universal one can i cant mount it on the firewall somewhere or it has to be close to the tank?
10-24-2011, 03:24 AM #6
fuel pressure regulator?
By JROBINSON1016 in forum External EngineReplies: 2Last Post: 07-14-2011, 07:55 PM -
Question: I have a Bad fuel Pressure Regulator
By z28punk in forum General HelpReplies: 15Last Post: 05-21-2010, 04:09 AM -
Fuel pressure regulator q
By grandkodiak in forum LT1Replies: 2Last Post: 08-11-2009, 07:41 PM -
By Goldcuffs in forum General HelpReplies: 0Last Post: 04-28-2009, 04:36 PM -
By 99camls1 in forum External EngineReplies: 0Last Post: 04-05-2009, 05:53 PM
