Results 1 to 3 of 3
    Junior Member JROBINSON1016's Avatar
    NORTH CAROLINA
    RED
    1998 TRANS AM
    fuel pressure regulator?
    i've been having a problem with my car cranking after it's sat for a while, over night or a few hours
    i noticed that if i turn the switch on & off a few times it will crank right up
    doesnt seem to be the fuel pump because it runs as always,runs great, no codes,etc.
    just seems like i have to get the fuel pressure built up then it'll crank & run fine
    seems like it's loosing pressure on the fuel rail
    how would i know if it's the fuel pressure regulator
    i wouldn't think it was the fuel pump or seems performance would be down,sluggish or run rough
    any ideas????
    East of Cleveland, Ohio
    99 WS.6 - Modified
    Have you replaced the fuel filter recently? If not, I'd start with that. If so, check to see what pressure you are getting at the rails when you first turn on the key, without starting the car. You should see 58-60 psi.
    Orlando, FL
    Mean Black
    check the fuel pressure at the rail like Knight mentioned. also put the guage that you can see it when you turn the key on (priming the fuel pump). the pressure should go up to like 58-60 and stay there after the pump stops priming. If it doesn't you have a leak somewhere. mine was in the flex tube of the fuel pump inside the tank. the car will start but it takes alittle longer sometimes. Here is the videos of what it looks like when mine was leaking pressure.
  1. Help: fuel pressure regulator
    By Firebirdformula99 in forum General Help
    Last Post: 10-24-2011, 03:24 AM
  2. Question: I have a Bad fuel Pressure Regulator
    By z28punk in forum General Help
    Last Post: 05-21-2010, 04:09 AM
  3. Fuel pressure regulator q
    By grandkodiak in forum LT1
    Last Post: 08-11-2009, 07:41 PM
  4. fuel pressure regulator
    By Goldcuffs in forum General Help
    Last Post: 04-28-2009, 04:36 PM
  5. fuel pressure regulator?
    By 99camls1 in forum External Engine
    Last Post: 04-05-2009, 05:53 PM
