Results 1 to 17 of 17
    Junior Member TruThug's Avatar
    La Vergne, TN
    1999 Firebird
    speedometer needle jumping???
    It works fine for a couple of mins after I start it up but once I drive after that the needle starts jumping up and down. It does not have a certain speed that it starts jumping just happens whenever. When I come to a complete stop it again jumps up and down just to reach 0. Why is this happening? Also Everything is stock.
    Sounds like a wiring or connection issue.
    Jun 2012
    near Augusta, GA
    2000 Trans Am WS6
    Quote Originally Posted by TruThug View Post
    What wound up being the problem with your speedo needle jumping around? My 2000 TA has been having the same problem.
    Member Ant71130's Avatar
    Aug 2010
    Lebanon, OH
    2002 M6 WS6
    Please correct me if I'm wrong, I haven't had this issue with a newer car but is the speed sensor connected to a gear in the tranny or diff? Sometimes when those gears get stripped it can cause fluctuation. However if it doesn't go back to 'correct' after it jumps and simply bounces then I'd say it's electrical for sure.
    Jun 2012
    near Augusta, GA
    2000 Trans Am WS6
    Quote Originally Posted by Ant71130 View Post
    Mine is definitely electrical. It only happens in warm weather. I already had the Vehicle Speed Sensor replaced. I just ordered a new ECM off ebay - hopefully that will fix it.
    phoenix
    04 2500 4x4 crew cab
    The only time I saw that happen on my car was a bad alt. And it went crazy continously. You may have a bad BCM. Body Control Module.
    Jun 2012
    near Augusta, GA
    2000 Trans Am WS6
    Quote Originally Posted by az gt eater View Post
    Is the BCM physically located under the hood or in the passenger compartment?
    My speedo needle falls when I gradually push on the gas. If I push the gas down hard, it doesn't tend to do it. At lower speeds, it will cause the transmission to downshift. That's really annoying. It's been doing it for quite a while.
    Member MudStainKILLA's Avatar
    Dec 2009
    Stateside
    2002 firebird T/A WS6-A4
    +1 to the alt as a possibility, my bird was doing some odd stuff electrinics wise and it turned out to be a bad alt and low battery.
    Jun 2012
    near Augusta, GA
    2000 Trans Am WS6
    Quote Originally Posted by MudStainKILLA View Post
    The battery was replaced within the last year. You have to figure that I am an old guy, when I say it's been doing it "for a while" I mean it's had the problem for at least 5, maybe 6 years.
    Dec 2009
    Stateside
    you wern't joking when you said a while! well i guess that rules out that as a possibility...
    2002 Trans Am WS.6 A-4:
    Volant CAI, BBK LTs, BBK ORY, SLP LM2, FROST Tune, A/C Heat Delete, AIR Delete
    phoenix
    I don't have much more to add. I do know that your speedo doesn't have a cable running to the instrument cluster. The cluster just snaps into a wire connector. I would think that somewhere in the tranny there is an actual gear. Maybe that is your problem. Stripped out, or skipping. I reread your first post, and I would say that it most likely is your BCM. It is located up in front of pass foot well. I have no experience with it, but have seen many threads about it. http://www.ls1.com/forums/f6/radio-p...e-time-165868/ Here's one. http://www.ls1.com/forums/f6/electrical-problem-165491/ Here's another one with some helpful pics from Smittro.
    Jun 2012
    near Augusta, GA
    2000 Trans Am WS6
    If I let it idle with the AC on then it does it really bad (when I start driving). I'm thinking it's related to the temperature under the hood. That's why I just went ahead and ordered the ECM. I'll let you know if that fixes it.
    Jun 2012
    near Augusta, GA
    2000 Trans Am WS6
    I got the ECM and installed it. Very straightforward, easy install. Car drove a little funny the first couple miles while the computer was learning. Unfortunately, today is very cool outside so there's no way for me to know yet if it fixed the speedometer problem.
    phoenix
    Keep us posted, im sure this will help someone else down the road.
    Jun 2012
    near Augusta, GA
    2000 Trans Am WS6
    Here's a video that shows what happens with the speedo needle. I made the video last month while driving down the interstate.
    http://img100.imageshack.us/img100/9810/47c.mp4
    Jun 2012
    near Augusta, GA
    2000 Trans Am WS6
    Bad news! The new ECM did not fix the problem. I may just take the car to a shop to have it fixed. No sense in continuing to guess at the cause of the problem. May take a little while though. Our other vehicle got hail damage this week and we just dropped it off for repair.
    Jun 2012
    near Augusta, GA
    2000 Trans Am WS6
    Update - after a few days, the new ECM started doing crazy stuff: the AC wouldn't work, the car ran bad and wouldn't start when hot. I pulled the new ECM and put the old one back in. Now the car is right back to where it was before - the speedo needle jumps but otherwise the car works fine. No returns on the ECM so I guess that's just money wasted.
  1. Improving Pontiac Speedometer Accuracy - Speedometer Super-T
    Last Post: 02-27-2012, 09:10 PM
  2. maybe jumping ship
    By brendan.9 in forum Almost Anything Goes
    Last Post: 04-01-2011, 11:28 AM
  3. Spark jumping
    By Durango in forum External Engine
    Last Post: 06-03-2009, 02:18 PM
  4. Help: Speedometer needle stopped working?
    By onetroubledguy in forum Firebird / WS6
    Last Post: 01-10-2009, 02:51 PM
  5. Boat Jumping
    Last Post: 08-19-2008, 11:42 PM
