    Member joker's Avatar
    Feb 2006
    North Carolina
    2002 Pontiac Trans Am WS6
    Harmonic Balancer
    Hello all
    I have had underdrive pulleys put on my 2002 ws6 a few years back. I need to replace the harmonic balancer due to some wobble. I am not sure if that was replaced. I am wondering if I order a street performance replacement if it will be the same ? Any help is welcome , Thank You .
    UMI sfc,whisper lid,k-n,diablo,shift kit,kooks long tubes-N-y-pipe,Borla 3" cat-back,power bond underdrive pulley,msd wires,front- baer gt brakes, slotted and drilled rotors , braided lines,tuned and dyno'd.345 HP and 354 torque
    Madison, WI
    1999 Formula WS6 M6-sold
    2001 Silverado Z71
    usually the only pulley replaced for underdrive pulleys is the harmonic balancer
    sure the wobble isn't due to the bolt being loose? Might just need a new bolt.
    North Jersey
    Phantom Black Metallic
    2004 GTO M6
    Most aftermarket pulley kits will require "keyeing" the crank and replacement pulley as well. Before you bolt the new pulley in, you will have to drill a hole between the crank and pulley to keep the pulley from walking off the crank snout.
  1. Harmonic Balancer
    By Camaro69Mac in forum General Help
    Last Post: 05-20-2010, 01:42 PM
  2. Harmonic balancer
    By 00hawk109 in forum External Engine
    Last Post: 06-12-2009, 07:34 PM
  3. Question: LS2 harmonic balancer into LS6?
    By LS2ddz28 in forum Internal Engine
    Last Post: 03-12-2008, 07:17 AM
  4. Harmonic Balancer
    By TwistedSS in forum External Engine
    Last Post: 05-16-2006, 07:30 AM
  5. harmonic balancer
    By Mr. CarelessAndImprudent in forum External Engine
    Last Post: 11-06-2005, 08:22 AM
