Results 1 to 3 of 3
Thread: Harmonic balancer
06-11-2009, 09:11 PM #1Junior Member
- Apr 2009
- Sanford, NC
Red- 2000 Pontiac Firehawk
Harmonic balancer
Just wondering if anyone here has changed one of these out. If so, what did it entail and how hard is it? Thanks.
06-11-2009, 09:25 PM #2
its pretty easy. the bolt is Very tight, so it might be hard to break loose. when I did mine I slid a prybar through one of the hole and under the motor to keep it from turning over and broke it loose with a 2 foot 1/2" drive breaker bar. then used a pully puller( you might need to grind some off of the puller jaws to get between the pully and front cover)
get a longer bolt to start the new balancer on (if you use the standard length bolt you might pull treads out of the crank)
once the balancer is close to being in position use your old bolt to force it back on the crank, then put locktite on the bolt and torque it back down.....i think it 240ft lbs
06-12-2009, 07:34 PM #3
fairly easy and straight forward swap. I would recommend making an installer out of some metric threadstock (m16x2.0pitch) and a few nuts and washer stack to push the pulley on. It just removes the chance of stripping the crank and makes getting that pulley on there very easy. The factory bolt is a torque to yield bolt so you have to use a torque wrench with an angle gauge or I went with an ARP balancer bolt and torqued to 240 ft/lbs.
Question: Harmonic Balancer
By joker in forum General HelpReplies: 3Last Post: 09-29-2011, 09:55 AM -
Harmonic Balancer
By Camaro69Mac in forum General HelpReplies: 8Last Post: 05-20-2010, 01:42 PM -
Question: LS2 harmonic balancer into LS6?
By LS2ddz28 in forum Internal EngineReplies: 1Last Post: 03-12-2008, 07:17 AM -
Harmonic Balancer
By TwistedSS in forum External EngineReplies: 1Last Post: 05-16-2006, 07:30 AM -
harmonic balancer
By Mr. CarelessAndImprudent in forum External EngineReplies: 15Last Post: 11-06-2005, 08:22 AM
