Results 1 to 20 of 82
Thread: Fuel rail covers question.
09-11-2011, 04:02 PM #1Senior Member
- Feb 2010
- north bay california
Black- 00 camaro ss M6 #6695
Question.... I'm looking at some c5 Corvette rail covers for $60 I think the price is not bad.
My question is how do they hold on the fuel rails or the engine?
Do they have something underneath the covers?
I'm going to get them in a few mins but I don't Know what to look for.
Thanks for the help..
09-11-2011, 06:12 PM #2Spaz is My Mentor
they have a C section that attaches to the fuel rails and on the bottom there are a couple of metal clips that attached to something on the coil packs.
I got mine for $55, I painted and did mine own work. Jump on them if you can
09-11-2011, 06:40 PM #3Senior Member
- Feb 2010
Thanks alot Scott.
I'll get them, usually go for way more on eBay or CL.
I was told I can modified them to make em fit?
Do I modified Both of them?
09-11-2011, 06:59 PM #4Spaz is My Mentor
you will need to
do you still have the air pump and stock headers?
09-11-2011, 07:05 PM #5Spaz is My Mentor
I can send some pics of mine to give you an idea
09-11-2011, 07:23 PM #6Senior Member
- Feb 2010
I have the stock manifolds. And the air pump. I'm getting LTs soon.
If you could send me pics pls [email protected]
Do i have to remove the air pump hose for that ?
09-11-2011, 07:41 PM #7Spaz is My Mentor
No but it means more to trim
09-11-2011, 07:46 PM #8Senior Member
- Feb 2010
If I need to remove the air pump hose I'll do it.
Do I need to cut the passenger side cover to make it fit if I got the egr?
09-11-2011, 07:58 PM #9Spaz is My Mentor
Delete the egr & air pump even if you don't have headers yet. But you live in Cali so you got other problems with emissions. Check with the cali members on what you can do.
09-17-2011, 04:33 PM #10Senior Member
- Feb 2010
i want to delete the air pump but idk if its hard to put it back on... for the emissinos..the egr im going to take it off
09-17-2011, 04:35 PM #11Senior Member
- Feb 2010
just got this..can some one tell what do i need to get them installed?
do i need to remove the air pump hoses?
09-17-2011, 05:45 PM #12
Man i am JEALOUS!!!
09-18-2011, 11:14 PM #13
09-18-2011, 11:40 PM #14
They look pretty sweet ... why wouldn't u be able to use them
09-19-2011, 12:41 AM #15Senior Member
- Feb 2010
The paint job looks cheap. I'm getting them painted, will have flames too. And some skulls
If I have to remove the air pump
Hoses. I don't think I'm gonna put the covers on.
Cuz if I remove the hoses I won't be able to pass the emissions.
09-19-2011, 12:50 AM #16
Ah that sucks
09-19-2011, 12:58 AM #17Senior Member
- Feb 2010
It does bro. Hate cali lol
09-19-2011, 03:13 AM #18
Make them look like this and they will fit with the secondary air system still on the car:
You have to unwrap the reflective heat tape from your fuel lines. Also, you should install heat tape to the underside of the covers if they do not already have it. No need to re-wrap the fuel lines as the cover will now insulate them from heat.
09-19-2011, 07:25 AM #19Spaz is My Mentor
Sorry Leo, I didn't get back to you on this, I've been busy.
Jeff is right, that is the exact way I did mine, even though I've deleted the Air/EGR. Since your getting them repainted go ahead and make all adjustments now.
I think you are having issues on the drivers side correct?
I had to disconnect the fuel line from the fuel rails and reroute the injector wire harness underneath the fuel line. Once I did that the FRC seated.
This cost me about $10 from O'Reilly. Works great on fuel lines.
I got my "Trans Am" and "5.7 stripe" from Afterthoughts
09-19-2011, 12:32 PM #20Senior Member
- Feb 2010
Thanks guys.
So if I remove the air hoses. I don't have to cut them or modified them??
Yeah the problem is the drivers side.
Looks complicated to install them.
On the drivers side I notice it has the hole for the fuel line.
Mine has only one.
The one on the picture jeff posted has two holes.
Do I have to make another hole for the fuel lines?
For Sale: LS1 Fuel Rail Covers with 2 Fuel Line Cutouts - Cut for F-Bo
By '99 SLP#24 in forum Parts For Sale / TradeReplies: 2Last Post: 01-11-2011, 06:24 PM -
New Fuel Rail covers
By TheSilverSurfer in forum Appearance SectionReplies: 6Last Post: 10-28-2007, 10:32 AM -
WTT Vette Fuel Rail Covers For Fuel Rail Covers
By LS1GMCTruck in forum Parts For Sale / TradeReplies: 1Last Post: 08-27-2006, 05:54 AM -
Fuel Rail Covers
By tajoe in forum Firebird / WS6Replies: 4Last Post: 03-25-2006, 01:17 PM -
question about fuel rail covers
By philsls1 in forum Appearance SectionReplies: 4Last Post: 03-08-2006, 06:08 PM
