Thread: question about fuel rail covers
03-08-2006, 02:49 PM #1philsls1Guest
i have seen a few engine compartments on camaro and t/a that have the custom fuel rail covers. i would imagine that they came off of a corvette. my question is where do you find these and are they difficult to install. they look awesome on there but when i look under my hood they also look like they would be a pain to put on.
03-08-2006, 02:56 PM #2Junior Member
- Feb 2006
- Cincinnati,OH
silver- 02 WS6
http://www.afterthoughtsauto.com/
Try These the same guy does them for both places.
edited to remove non-sponsor link.Last edited by keliente; 03-08-2006 at 05:24 PM.
03-08-2006, 04:51 PM #3philsls1Guest
hey thanks alot for the links. awesome. i found some posts about the rail covers in appearance section and sound like they might be a pain in the a$$ to put on. oh well for the look that they achieve guess its worth the pain
03-08-2006, 05:42 PM #4
They're really not that hard to install.
There are a couple minor things to do to prepare for the install tho.
The AIR tubes must be out far enough way from the engine so they don't interfere. (Easily, but carefully, bend outward during install if they seem to be in the way.)
The throttle cable bracket on the top/rear/driver's side of the intake manifold must be removed. Simply remove the nut with a 10mm socket & put the bracket away in a safe place in case you ever decide to put it back on. (Although it should never come to that.)
The wire bundles that are attached to both fuel rail tubes need to be removed from the top of the tubes & simply set down lower as they will hold up the covers & prevent them from sitting down properly. Simply squeeze the underside of the retaining clips to remove them, or pull hard & they come right out.
I know the other manufacturers send an installation sheet with theirs, as I do also.
Also, if you have a shock tower brace, it obviously must be removed for installation of the covers & then re-installed. The SLP STB will not work well with the covers, as it is made a bit shorter than other brands like the BMR & Hotchkiss. The SLP STB will rub on the top of the covers.
I bet you can install them within a 30 minute time period easily!
Good Luck!
03-08-2006, 06:08 PM #5philsls1Guest
thanks for reply pontiacfan. great info and was wondering about my hotchkiss stb and glad to see it will clear. now i just have to think up my design and contact afterthoughtauto.
Fuel rail covers question.
By 98maro in forum General HelpReplies: 81Last Post: 09-27-2014, 01:45 PM -
For Sale: LS1 Fuel Rail Covers with 2 Fuel Line Cutouts - Cut for F-Bo
By '99 SLP#24 in forum Parts For Sale / TradeReplies: 2Last Post: 01-11-2011, 06:24 PM -
New Fuel Rail covers
By TheSilverSurfer in forum Appearance SectionReplies: 6Last Post: 10-28-2007, 10:32 AM -
WTT Vette Fuel Rail Covers For Fuel Rail Covers
By LS1GMCTruck in forum Parts For Sale / TradeReplies: 1Last Post: 08-27-2006, 05:54 AM -
Fuel Rail Covers
By tajoe in forum Firebird / WS6Replies: 4Last Post: 03-25-2006, 01:17 PM
