Results 1 to 2 of 2
Thread: Tick master install
08-28-2011, 04:56 PM #1
Tick master install
I went to bench bleed the tick master and when I pressed the piece in that seals the end of the line (where it plugs into the transmission) it will NOT return all the way up. What do I do?
TICK unit:
STOCK UNIT:
as you can see, the stock unit piece is fully returned where it is sealed off, the Tick unit will constantly let fluid flow through it. I've tried pressing it in more to see if it will return and no dice. Help.
08-28-2011, 05:04 PM #2
After playing with it for a while it finally came unstuck and returned to the correct position. The tick unit it just 'sticky' and hangs up when you press it in. A little brake fluid should lube it up.
False alarm.
Master Cylinder Swap/Install (Tick MC)
By tatertot91 in forum Manual TransmissionReplies: 6Last Post: 05-06-2018, 05:39 PM -
Tick master cylinder
By johnfin in forum Firebird / WS6Replies: 30Last Post: 08-30-2012, 05:18 AM -
everyone should get a Tick master cylinder
By eatin mustangs in forum Manual TransmissionReplies: 7Last Post: 05-27-2012, 08:55 AM -
Help: Tick Master Cylinder
By Hacked98WS6 in forum Manual TransmissionReplies: 2Last Post: 11-24-2010, 05:48 PM -
wtb tick clutch master
By southpaw0314 in forum Parts Wanted / TradeReplies: 0Last Post: 01-17-2010, 12:07 PM
