Thread: bumping limiter on 2-3 shift
08-22-2011, 06:27 PM #1Member
- Jun 2009
- nor cal
white- 1998
Hey guys, finally back to the ls world and hopefully here to stay. Just picked up a 99 z28 thats got a few things done to it. As far as the trans, I'm told it has a tci 3000 stall and a stage 2 shift kit. I don't know what kind though. I can feel that it has a stall and it runs and drives great. My only problem is if I'm wide open between the 2-3 shift it bumps the limiter. The kid said the car was tuned for the stall and shift kit but i don't know. The tranny fluid levels good. Should I try ordering a frost tune and hope it helps or bring it into a shop? It needs a tune anyway because the cel is on because of the exhaust
Thanks
08-23-2011, 04:42 AM #2
sounds like it might just be a tuning issue.....where's the limiter set on it? After my stall install I bumped the limiter a couple times before I adjusted shift points.
08-23-2011, 07:30 AM #3Member
- Jun 2009
- nor cal
white- 1998
I'm hoping it is. The kid said it was already tuned but i think hes full of it. I think its the stock limiter. around 6200-6500?
08-23-2011, 07:32 AM #4Senior Member
- Mar 2010
- St Pete, FL
Bat mobile black- 2000 Trans am WS6 M6
most likely it isnt tuned, just get a frost tune and you should be set
08-24-2011, 08:32 AM #5Member
- Jun 2009
- nor cal
white- 1998
ok I'll try that. and I know it has a stall but not sure what one. The kid said it was a tci 3000 but is there anyway of checking it without pulling the trans? I know thats part of the info frost needs. Its getting 12 mpg right now to, I know I didn't get the car to save gas but I need it a little better than that lol
08-24-2011, 05:14 PM #6Junior Member
- Oct 2006
- Myrtle Beach
Your shift at VSS and shift at RPM aren't tuned correctly if it's doing this.
08-24-2011, 09:01 PM #7Member
- Jun 2009
- nor cal
white- 1998
so a mail order tune would fix this right?
08-25-2011, 09:46 AM #8Member
- Jun 2009
- nor cal
white- 1998
And tuning out the rear o2s would turn off my ses light right? its on right now just for the rear o2s
still hitting limiter on 2/3 shift after tune?
By pk222 in forum Automatic TransmissionReplies: 14Last Post: 11-10-2011, 02:55 PM -
bumping limiter on 1 2 shift
By pk222 in forum Automatic TransmissionReplies: 17Last Post: 05-22-2010, 10:17 AM -
4l60 trans bumping rev limiter 7000 1,2,3
By sloroller in forum Automatic TransmissionReplies: 20Last Post: 04-17-2010, 04:43 PM -
4L60 hits the rev limiter during 2nd to 3rd shift
By maxwax in forum Automatic TransmissionReplies: 6Last Post: 07-12-2009, 08:01 AM -
Question about rev limiter and shift points
By MikeMoss in forum Camaro / SSReplies: 4Last Post: 04-13-2007, 08:06 PM
