Results 1 to 20 of 21
    Junior Member sloroller's Avatar
    Apr 2010
    al
    01 camaro ss
    4l60 trans bumping rev limiter 7000 1,2,3
    hey trying to get some direction are were to go next. 01 ss full bolt ons 4000 circle d stall 10 bolt rear 4.10 gears and a custom grind cam 614 lift im thinking. Just left the tune shop lowered my shift speeds by 17% and lowered my shift points and still bangs the limiter. maybe i need to contact frost.
    Senior Member bills98ta's Avatar
    Feb 2007
    St Thomas, PA
    Are you leaving it in drive or over drive ? Mine won't shift by it self any other way.
    Apr 2010
    al
    01 camaro ss
    I'm leaving it in overdrive
    Feb 2007
    St Thomas, PA
    They need to lower the mph and rpm shift points for each gear. Take it back and try again... What are they tuning with ? HP Tuners ?
    Feb 2007
    St Thomas, PA
    My 1 - 2 shift is set at 29 mph and 6200 rpm to achieve a 7000 rpm shift. My limiter is at 7400...
    Apr 2010
    al
    01 camaro ss
    my begining shift was at 6000 and shift at 6800 limiter set at 7000 now he bumped it back at i think5600 with a shift point of 6300
    Apr 2010
    al
    01 camaro ss
    hp tuners
    Broken Arrow, Ok
    2000 Z28
    Quote Originally Posted by sloroller View Post
    Set at 5600 with a shift poing of 6300. This is just me but it sounds like the tranny is starting to go. I would double check with Frost. When your shift points were set higher I would not have said that. I would have backed down or gone back to stock shift points to see.
    Broken Arrow, Ok
    2000 Z28
    Quote Originally Posted by bills98ta View Post
    Are you on stock Rod Bolts?
    Feb 2007
    St Thomas, PA
    H-Beam Rods / ARP's and lunati +12cc dome pistons / 5.3 heads done up yielding 14:1 CR. 4600 stall / 4.10 gears. 150 shot too / ect.. .The tuner might want to do some comparison's on other transmission tunes to tweak it in...
    Feb 2007
    St Thomas, PA
    I ran my stock bottom end with the same set up, until it pulled a rod bolt.
    Feb 2007
    St Thomas, PA
    He has to lower the mph shift points too. They can be zeroed but I didn't.
    Apr 2010
    al
    01 camaro ss
    Dont know much about the internals other than having comp springs ls6 block and full slp exhaust fast 92 intake fast big mouth 92 tb slp lts slp cme and full suspension work with qa1son all corners, ut pretty much stock also has 243 heads no work done to them.
    Apr 2010
    al
    01 camaro ss
    stock rod bolts
    Apr 2010
    al
    01 camaro ss
    Any ideas about breaking the tens on motor with my set up na motor?
    Feb 2007
    St Thomas, PA
    I had my stock bottom motor hitting 10.8's with a 150 dry shot. Walbro 255 fuel pump & 30lb injectors at the time. And a little more tuning ! LOL
    Apr 2010
    al
    01 camaro ss
    Went back to my tuner and dialed it in a little and fixed it, went to the the track and had no problems. thanks for the input
    Feb 2007
    St Thomas, PA
    Get any good times ?
    Apr 2010
    al
    01 camaro ss
    ran 11.4 on the car @118 n/a cam and olt ons stock heads 7.2 through the eighth
    Feb 2007
    St Thomas, PA
    Not bad at all !!! 4000 stall, I'm guessing a 1.4X - 60' ???
  1. 99 Trans Am $7000 obo
    By ehale in forum Vehicles For Sale / Trade
    Last Post: 12-31-2015, 06:35 PM
  2. Help: bumping limiter on 2-3 shift
    By pk222 in forum Automatic Transmission
    Last Post: 08-25-2011, 09:46 AM
  3. bumping limiter on 1 2 shift
    Last Post: 05-22-2010, 10:17 AM
  4. 4L60 hits the rev limiter during 2nd to 3rd shift
    By maxwax in forum Automatic Transmission
    Last Post: 07-12-2009, 08:01 AM
  5. Clunking and bumping noises-Trans mount?
    By chvydav99 in forum General Help
    Last Post: 11-05-2006, 07:19 PM
