Results 1 to 15 of 15
Thread: Rear Bump Stops from Sponsor
08-09-2011, 12:28 PM #1
- Apr 2009
- Pennsylvania
Pewter- 2000 Camaro SS
Hi,
Looking for some rear bump stops. I took my rear wheel off yesterday and found the bump stop was half gone. It is crumbling apart.
Looking to see if a sponsor has these?
I called GM and they told me they were obsolete, but gave me a gm part number 10282449.
Thanks,
08-09-2011, 01:56 PM #2
I do not believe that any of our sponsors offer replacement bumpstops. I would check with Hawks Third Gen, Energy Suspension, or P-S-T as possible sources. If you are simply looking for a stock replacement piece, then check with the guys at Trans Am Creations.
08-10-2011, 09:31 AM #3
- Apr 2009
- Pennsylvania
have you or anyone you know ever used these?
Last edited by 35th-ANV-SS; 08-14-2011 at 07:55 PM. Reason: removed link to non-sponsor
08-10-2011, 10:04 AM #4
Hawks third gen deffinetely has them. Got em in red or black. I believe they are 130 for both. Dont quote me on the price. Lifetime warranty too.
Suspension: Lower control arms (Spohn), Drive shaft safety loop, Torque arm (Edlebrock), Strut tower brace, Panhard Bar (BMR)
Under the Hood: Smooth bellows, Lid, Catch can, LT Headers, ORY, AIR/EGR delete, Poly engine/transmission mounts,
Exterior: Painted brake calipers (Red), Halo “Spyder” Headlights w/matching parking/turn signals (Black)
08-10-2011, 11:27 AM #5
[QUOTE=1slowbusa;2688946]have you or anyone you know ever used these?
Yes I have it. Worth it. You will need to do a minor mod. Need to grind down the lip on the frame to let the bump stop sit right. No big deal. Took me 20 mins. Beats paying $100.Last edited by 35th-ANV-SS; 08-14-2011 at 07:55 PM. Reason: removed link to non-sponsor
08-11-2011, 04:27 AM #6
- Apr 2009
- Pennsylvania
08-11-2011, 08:58 AM #7
Wow. Whats the major difference with these and ones from hawks third gen? Why the price difference?
08-12-2011, 04:49 AM #8
- Apr 2009
- Pennsylvania
What i understand is the third hawks are stock replacement and the stops i ordered a little grinding needs to be done to make them fit. i would rather do a little grinding than pay over 100 dollars for the bump stops and after reading multiple threads on here and ls1tech aftermarket work fine and do the job.
08-12-2011, 07:30 AM #9
1slowbusa,
I bought and installed the Strano Bump stops on my SS. They were black in color and was $35-40 total with shipping. my passenger side rear was destroyed, drivers still looks good as new.
I have had ZERO issues with them. however, I did have to grind off on the metal bumpstop bracket. I took pics of my install, but have not done a write-up on it. it's easy and straight forward.
As for HTG, they rape everyone on prices, period. Sad thing is, people willingly choose to pay those insane prices. i don't get it.
08-12-2011, 08:02 AM #10
I recommend using a 4" grinder. The metal is thick enough that a Dremel will take to long. Now if you have a plasma cutter, 5 mins top.
Don't go all crazy when taking it off, just remove a little at a time. Also use some spray paint to cover the bear metal after cutting so you don't have a rust spot.
08-12-2011, 08:08 AM #11
ooo, i need to clarify.
when i said i had to modify the bumpstop bracket, i ment the actual 'spacer' insert piece. i did not have to do anything to the bracket that is on the car itself.
i didnt have a grinder, i got to do it using a hacksaw and filing down the rest. took me about 1.5 hrs total cause of that.
i will pull the pics off my camera and post up later tonight.
08-12-2011, 08:21 AM #12
I just cut the bracket off the car itself. Took about 30 mins both sides. I have the SLP spacers but again they need to be grind down in order for the bump stops to fit. I haven't don't it yet.
08-13-2011, 08:04 AM #13
- Apr 2009
- Pennsylvania
Thanks for the replies everyone.
SSwt00SS
I look forward to the pics of the install
08-13-2011, 11:33 AM #14
here are my pics from beginning to end on the passenger side. obviously, same process for the drivers side
you can see where i had to hacksaw off on the SLP Spacer since i don't have a grinder.
factory bumpstop on the left and aftermarket on the right:
08-13-2011, 12:41 PM #15
- Apr 2009
- Pennsylvania
Thanks, SSwt00SS
I think this should be a sticky for future info.
Rear bump stops
By JayTA98 in forum General HelpReplies: 0Last Post: 04-03-2010, 04:06 PM -
rear axle bump stops
By 2000redcamaro in forum Camaro / SSReplies: 8Last Post: 08-27-2009, 09:24 PM -
Cutting off rear bump stops
By Jason Polzer in forum Wheels and TiresReplies: 15Last Post: 03-23-2008, 07:46 AM -
Where Can I Get Some Poly Bump Stops (Rear Axle)
By CJREX in forum Suspension and HandlingReplies: 2Last Post: 01-08-2008, 11:01 AM -
Rear Bump Stops w/ Eibach Pro Kit Springs
By T/Aboo in forum Suspension and HandlingReplies: 4Last Post: 02-27-2006, 05:27 AM
