02-24-2006, 01:44 PM #1
- Jan 2006
- New Orleans, LA
Red- '01 Trans Am WS.6
Rear Bump Stops w/ Eibach Pro Kit Springs
I removed the aluminum spacers between the rear bump stop bumbers on my WS.6 when I installed my Eibach springs. They lowered the car about 1.5 inches and it seemed to make contact with the bump stops frequently before I removed the spacer. Is this something other people have noticed as well? My question is, does anyone make a stiffer bumber for this application? Maybe something polyurethane?
02-24-2006, 02:34 PM #2
don't completely remove them. cut about half of the rubber off.
02-25-2006, 07:29 PM #3
- Jun 2002
- Montreal, CANADA
I'd get something more gradual than the SS/WS6 bumsptops... like getting the TA or Z28 one.. you get a better feel and way more gradual than keeping those.
Putting something harder will hinder you... that will make the rear spring rate sky-rocket and make you lose traction on the rear of the car... not something you want to do when cornering.Eugenio_SS
02-27-2006, 05:22 AM #4
- Jan 2006
- New Orleans, LA
Thanks for the help guys. I'll try putting a std T/A rubber in there and see what happens.
02-27-2006, 05:27 AM #5
- Commerce Ga
Black, Blue- 07 TBSS, 07 GSXR1000
Just lowered my car with Eibach Pro kit and KYB AGX's and no problems here.
Rear Bump Stops from Sponsor
By 1slowbusa in forum Suspension and HandlingReplies: 14Last Post: 08-13-2011, 12:41 PM -
Rear bump stops
By JayTA98 in forum General HelpReplies: 0Last Post: 04-03-2010, 04:06 PM -
rear axle bump stops
By 2000redcamaro in forum Camaro / SSReplies: 8Last Post: 08-27-2009, 09:24 PM -
Cutting off rear bump stops
By Jason Polzer in forum Wheels and TiresReplies: 15Last Post: 03-23-2008, 07:46 AM -
Where Can I Get Some Poly Bump Stops (Rear Axle)
By CJREX in forum Suspension and HandlingReplies: 2Last Post: 01-08-2008, 11:01 AM
