Results 1 to 10 of 10
    The red dragon bpopham22's Avatar
    Feb 2010
    San antonio Tx
    2001 pontiac WS6
    head cam swap,rocker rebuild?
    Ok heres the plan,I'm going to order my prc stage 2.5 heads along with the comp 212 218 high lift cam. Should I have the rockers rebuilt for the new heads or can I use them as is? Car has 95xxx miles on it.
    Member jetaws6's Avatar
    Apr 2009
    Fallston, Maryland
    1998 Trans Am Ws6
    what are the cam specs? It should be fine to reuse them just torque them in right.
    Laurel, Maryland
    2000 Grand Prix GTP
    2000 Trans Am WS6 M6
    Quote Originally Posted by bpopham22 View Post
    Two things...
    1. That is a REALLY small cam...I would at least get a 228R cam to take advantage of those heads. Personally, I'd get a Torquer V2 cam...I loved mine with my Ported/Milled 5.3L heads.
    2. I'd get the Trunion bearing upgrade for your stock rockers. I got it for my stock rockers (77k) and I'll be using them on my 427 LS3.
    2000 Pontiac Trans Am WS6 M6: 427ci LS3, Built T56, Moser 9" w/ 4.11 Gearing, Full Suspension, and 6-point Cage.
    2000 Pontiac Grand Prix GTP: Twincharged w/ a T67 Turbocharger
    2007 Chevrolet 3500 Dually Duramax: 3" Downpipe, Dual 4" Exhaust, EFILive Tuning
    NC
    1998Z28
    Your stock rockers will be fine. I don't think you'll be happy with that cam. It is the same one I started out with and it was a total disapointment. I was changing it out for a Torquer V2 within 2 months and very happy with the outcome. When I added stage1 243 PRCs later it picked up 50 rwhp on the dyno. A TV2 with Stage 1 243 PRCs pulls hard thru its power band. Stage 2.5s might be overkill. The cam your talking about putting in is about the same as a stock Vette cam.
    TSP 347 SB, TSP Stage 2.5 PRC LS6, TSP MS4, Performabuilt Stage 2 4L60E, Yank PT4000, 4.11s, Fast 90/90, FTRA Cold air intake+all the free mods, Dynatech Supermaxx Exaust System, DMH Cutouts, Hooker Catback/FTRA Tips. Tuned by RPM/Garner NC. 11.28@119
    Feb 2010
    San antonio Tx
    2001 pontiac WS6
    I know its a baby cam,that's what I want.(keeping stock converter till my tranny shits out) I'm gonna have to look up the trunion bearing upgrade.
    Laurel, Maryland
    2000 Grand Prix GTP
    A cam install is no small feat...you'll have to remove the radiator, water pump, crank pulley, front cover, oil pump, timing chain, remeasure the push rods for correct length, then get a retune for the new cam.
    I'm telling you now, putting that cam in is a waste of time and money. I 100% guarentee, you'll be VERY disappointed that you're time and effort got you sub 400rwhp numbers.
    Apr 2009
    Fallston, Maryland
    1998 Trans Am Ws6
    Yes x1000. I have a 228r in mine now and wish I would have gone bigger. 228r should be good for a stock stall though if thats really what you want but if I had an auto a good stall would be my first mod.
    Feb 2010
    San antonio Tx
    2001 pontiac WS6
    I know its a major deal that's why nelson performance is doing it for me. I want a stock like cam with dd properties.
    Laurel, Maryland
    2000 Grand Prix GTP
    This makes it sound like you shouldn't change out the cam at all.
    I had no problem driving my Torquer V.2 cam on the street. If you're worried about it not driving stock, then drop down to a 228R cam. If you want it to sound like stock, then get a high LSA, like 114 or 115. There will be no choppy-ness and you'll have the power you want.
    Senior Member Lunatikgixxer's Avatar
    Mar 2010
    St Pete, FL
    Bat mobile black
    2000 Trans am WS6 M6
    listen to ls1camino. I have an m6 with a tsp 233/239 camshaft and my car is a DD. I have no problems driving it when it comes to the cam, now the clutch is a different story. I dont even know why you would even consider doing all that work and spending that money to put that cam in, thats like taking your ls1 cam out and putting a ls6 cam in. Waste of time and money imo, the smallest cam id go with a 228r ATLEAST! Especially if youre buying heads too.
  1. 358 Small Block Cylinder Head & Rocker Arm Upgrade
    Last Post: 04-03-2009, 02:50 PM
  2. swap or rebuild
    By maskedman58 in forum Automatic Transmission
    Last Post: 01-18-2009, 07:49 PM
  3. Turbo, Pacesetters, 4L60, head bolts, rocker arms
    By 98Camarod in forum Parts For Sale / Trade
    Last Post: 11-01-2008, 02:42 PM
  4. 1.6 in Rocker swap for 400 Pontiac
    By Bandit400 in forum Classic Muscle
    Last Post: 05-06-2008, 04:27 PM
  5. Pistons, Rocker Arms and Head bolts
    By ONTheGunLS1 in forum Parts For Sale / Trade
    Last Post: 03-31-2006, 11:43 PM
