Results 1 to 19 of 19
    Senior Member Lunatikgixxer's Avatar
    Mar 2010
    St Pete, FL
    Bat mobile black
    2000 Trans am WS6 M6
    Will a "ghetto rigged" PCV system cause a high idle?
    My PCV system is set up like its suppose to be with a catch can but minus the catch can. So the hoses are just dumped to the bottom of my motor... Would this cause a high idle?
    Junior Member Mr_Rich's Avatar
    Santa Maria, California
    1998 Pontiac Formula LS6
    It's essentially a metered vacuum leak. If you plug the hose, does the idle drop?
    so is the intake sucking air? If so it's a vacuum leak and will cause your high idle.
    Member mike171562's Avatar
    Feb 2010
    Houston, Tx
    1998 WS6 T/A
    with a catch-can but MINUS the catch-can????
    pls post a pic
    Mar 2010
    St Pete, FL
    Bat mobile black
    it is set up like this http://www.ls1tech.com/forums/attach...cv-1ls1ext.jpg
    but i have no catch-can. I have the instake valve that sucks air in capped off so there is no vacuum leak there...
    Feb 2010
    Houston, Tx
    1998 WS6 T/A
    I have mine setup like this, no high idle here. i would check for leaks in your hoses.
    Member jetaws6's Avatar
    Apr 2009
    Fallston, Maryland
    1998 Trans Am Ws6
    Whats the green dotted line? Is that blocked off?
    Mar 2010
    St Pete, FL
    Bat mobile black
    mike do you have a catch can though?
    Feb 2010
    Houston, Tx
    1998 WS6 T/A
    No catch can , I may add one later, but its running fine without one. I switched from 98 valve covers to ls6 valve covers which dont have the extra nipple on the back passengers side.
    Mar 2010
    St Pete, FL
    Bat mobile black
    damn thats weird, the idle gets worse when the AC is on too... I will check for leaks
    Mar 2010
    St Pete, FL
    Bat mobile black
    ok so i checked everywhere and i checked the back of the intake and found this, i think i forgot to put it back on when i put my manifold back on... Where does it go?
    Apr 2009
    Fallston, Maryland
    1998 Trans Am Ws6
    on the back next to the map sensor and that would cause the idle issue
    Mar 2010
    St Pete, FL
    Bat mobile black
    where exactly is that? i cant see jack shit back there.. What if i just cap it off?
    Apr 2009
    Fallston, Maryland
    1998 Trans Am Ws6
    yep that's it and it's a PITA to try to get on with large hands.
    Feb 2010
    Houston, Tx
    1998 WS6 T/A
    I have big hands and you can get them back there if you get in at the right angle. its pointing toward the passengers side on the back of the intake
    Mar 2010
    St Pete, FL
    Bat mobile black
    i have skinny hands. Ill try it.
    Mar 2010
    St Pete, FL
    Bat mobile black
    ok turns out the picture jetaws6 sent, that piece is connected, the other side is the side that is disconnected.
  1. A New Democrat Email Scandal - DNC "Rigged" Primary
    Last Post: 07-26-2016, 05:49 PM
  2. 1977 Pontiac LeMans - "High Speed Pursuit" Of Happiness
    Last Post: 10-04-2010, 05:40 PM
  3. "boot failure insert system disk" Computer ???
    By ssgtcarroll in forum Almost Anything Goes
    Last Post: 12-13-2009, 04:50 PM
  4. Replies: 26
    Last Post: 03-02-2007, 07:45 AM
  5. 1995 Nissan Silva - High-End "Hybrid"
    By Ed Blown Vert in forum Stereo and Electronics
    Last Post: 11-29-2006, 01:30 AM
